1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: SynApps build error : win32-x86
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Jun 2012 20:27:45 +0000
The tools are called dmake and gmake.  How are those conflicting, or is it something else in that folder?
Sent: Tuesday, June 26, 2012 3:05 PM
To: [email protected]
Cc: S. Stein; Mark Rivers
Subject: Re: SynApps build error : win32-x86
Hi S,
On 2012-06-26 S. Stein wrote:
> There is no "make" within strawberry/perl/bin:
Look in C:\strawberry\c\bin where the other tools are (I've just installed the
same version as you):
C:\strawberry>dir c\bin\*.exe
 Directory of C:\strawberry\c\bin
11/02/2011  11:56 AM           582,144 addr2line.exe
11/02/2011  11:56 AM           604,160 ar.exe
11/02/2011  11:56 AM         1,047,552 as.exe
11/02/2011  11:56 AM           215,552 c++.exe
11/02/2011  11:56 AM           581,120 c++filt.exe
11/02/2011  11:56 AM           214,016 cpp.exe
11/02/2011  11:56 AM           633,344 dlltool.exe
11/02/2011  11:56 AM            47,616 dllwrap.exe
01/10/2010  10:50 AM           135,898 dmake.exe
11/02/2011  11:56 AM            32,256 elfedit.exe
11/02/2011  11:56 AM           215,552 g++.exe
11/02/2011  11:56 AM           212,480 gcc.exe
11/02/2011  11:56 AM            36,864 gcov.exe
05/03/2011  02:42 AM           176,640 gmake.exe
11/02/2011  11:56 AM           642,048 gprof.exe
11/02/2011  11:56 AM           215,552 i686-w64-mingw32-c++.exe
11/02/2011  11:56 AM           215,552 i686-w64-mingw32-g++.exe
11/02/2011  11:56 AM           212,480 i686-w64-mingw32-gcc-4.4.7.exe
11/02/2011  11:56 AM           212,480 i686-w64-mingw32-gcc.exe
05/06/2011  01:52 AM            63,820 iconv.exe
11/02/2011  11:56 AM           846,848 ld.bfd.exe
11/02/2011  11:56 AM           846,848 ld.exe
11/02/2011  11:56 AM           592,384 nm.exe
11/02/2011  11:56 AM           734,720 objcopy.exe
11/02/2011  11:56 AM         1,102,848 objdump.exe
05/06/2011  01:52 AM           739,042 openssl.exe
03/03/2010  05:17 AM           101,888 patch.exe
01/10/2010  10:50 AM            38,626 pexports.exe
05/06/2011  11:56 AM            99,211 pg_config.exe
11/02/2011  11:56 AM           604,160 ranlib.exe
11/02/2011  11:56 AM           313,856 readelf.exe
11/02/2011  11:56 AM           583,680 size.exe
11/02/2011  11:56 AM           583,680 strings.exe
11/02/2011  11:56 AM           734,720 strip.exe
11/02/2011  11:56 AM           605,184 windmc.exe
11/02/2011  11:56 AM           687,616 windres.exe
05/06/2011  01:52 AM            43,295 xmlcatalog.exe
05/06/2011  01:52 AM           109,304 xmllint.exe
05/06/2011  01:52 AM            55,067 xsltproc.exe
              39 File(s)     15,720,103 bytes
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: SynApps build error : win32-x86 Andrew Johnson
Re: SynApps build error : win32-x86 S. Stein
Prev: Re: SynApps build error : win32-x86 Andrew Johnson
Next: Re: SynApps build error : win32-x86 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
