Subject: ImageJ from waveform record
To: "tech-talk" <[email protected]>
Date: Wed, 4 Jul 2012 12:04:10 +0100
Is it possible to use the ImageJ plugin to display data being put into a waveform record from a source other than AreaDetector? I have an IOC with image data in a waveform and corresponding NX/NY/NZ records. I’m not sure what to use for the PVPrefix. I have just used the waveform record name, plus a :, but I get “Cannot connect to EPICS PVs” errors. I suspect this must be wrong.
Thanks
Steve
RE: ImageJ from waveform record Mark Rivers
Prev: caQtDM: a MEDM replacement Mezger Anton Christian
Next: 回复: Re: Re: Problems when download synApps IOC sunjl
Prev: Re: caQtDM: a MEDM replacement Emmanuel Mayssat
Next: RE: ImageJ from waveform record Mark Rivers
