Subject: Question about CA event (i.e. monitor) time order
To: EPICS <[email protected]>
Date: Thu, 05 Jul 2012 17:21:55 +0200
Hello,
Consider a client that subscribes for two PVs (here in particular two fields of the same record). Now the IOC (the record support) posts events on both fields. Is the time order of these two events preserved?
In other words, are the monitor callbacks of the client called in the same order as the IOC calls db_post_events()?
In my particular case, I have a client (with unknown source code) that sometimes sees value changes on two fields of the motor record, DMOV and RRBV, in the wrong order. Thus in the DMOV callback, RRBV still has the old value. I checked in the motor record that DMOV is always posted after RRBV.
Is there any mechanism in EPICS that could swap the execution order or should the problem be searched in the client?
Dirk
Re: Question about CA event (i.e. monitor) time order Andrew Johnson
Re: Question about CA event (i.e. monitor) time order Tim Mooney
Prev: Re: 回复: Re: Re: Problems when download synApps IOC Dirk Zimoch
Next: Re: caQtDM: a MEDM replacement Michael Johnson
Prev: Re: ImageJ from waveform record Steve Kinder
Next: Re: Question about CA event (i.e. monitor) time order Andrew Johnson
