Subject: RE: Problem in SNL
To: santosh aditya <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 6 Jul 2012 15:56:00 +0000
Did you correctly point to EPICS base in seq/configure/RELEASE?
From: [email protected] [[email protected]] on behalf of santosh aditya [[email protected]]
Sent: Friday, July 06, 2012 10:09 AM
To: [email protected]
Subject: Problem in SNL
I am using Ubuntu V 12.04 32-bit. I have installed EPICS base and extensions. I have started SNL programming. I have installed re2c-0.13.5 and seq-2.1.7.
I am unable to compile the state program. I have attached the program (.st) along with the environment variables.
I have tried to compile using " snc level_check.st -o level_check.c"
But when I compile this C file I am getting following error message
level_check.c:8:24: fatal error: epicsTypes.h: No such file or directory
compilation terminated.
Please help me to proceed further
Problem in SNL santosh aditya
Prev: Re: Problems with parallel make on seq-2-1-7 Andrew Johnson
Next: Re: Problem in SNL Benjamin Franksen
Prev: Problem in SNL santosh aditya
