Subject: Re: Problem in seq-2.1.8
To: [email protected]
Date: Tue, 10 Jul 2012 13:08:26 -0500
Hi Ben,
On 2012-07-10 Benjamin Franksen wrote:
> I intended the '#' character to be a comment for make, not for the shell.
In future releases of Base you can use $(NOP) as a command that does nothing,
but that only got added to the build files after 3.14.12.2 came out.  You can
use
	$(PERL) -e ''
on all platforms to do nothing (NOP is defined as : on non-windows systems
since that's faster).
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Problem in SNL santosh aditya
Re: Problem in seq-2.1.8 Benjamin Franksen
Prev: Re: Problem in seq-2.1.8 Benjamin Franksen
Next: Module for Labtech H150-1000 chiller Alan Greer
Next: stream device string/hex parsing Gerrit Kühn
