Subject: Re: EDM Segmentation fault
To: <[email protected]>
Date: Thu, 12 Jul 2012 16:29:54 +0200
On Thursday, July 12, 2012, Benjamin Franksen wrote:
> On Thursday, July 12, 2012, Zhang Yuliang wrote:
> > Hello all,
> > I am trying to install EDM-1-12-78 on a Redhat 4.8 32 bit machine and
> > am able to build it successfully. However, when I try to create a new
> > edl file or open an existing edl file , the EDM crashes with the error
> > of "Segmentation fault".
> > How to solve this issue?
> The very first thing is to inlcude the author (John William Sinclair
> <[email protected]>), as I believe he does not listen to tech-talk for
> bug reports.
> Then, make sure a core file gets generated. If not, enable this by
> issuing the command
> > ulimit -c unlimited
> on the shell before starting edm. Now, load edm (the executable) into a
> debugger (I use ddd as frontend to gdb), let it crash, load the core
> file, ask ddd to let you see the stack backtrace. Post this backtrace.
Sorry, this is confusing, what I meant to say:
1) start edm
2) let it crash
3) load edm (executable) into ddd
4) load core file
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
EDM Segmentation fault Zhang Yuliang
Re: EDM Segmentation fault Benjamin Franksen
Prev: Re: EDM Segmentation fault Benjamin Franksen
Next: Re: EDM Segmentation fault John William Sinclair
