1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: EDM Segmentation fault
To: "John William Sinclair" <[email protected]>
Cc: [email protected]
Date: Fri, 13 Jul 2012 09:02:03 +0800 (CST)
Hi John,
I have do some diagnostics follow your example. Here is my results,
cat $EDMOBJECTS/edmObjects
30
activeLineClass $(EDMLIBS)/libEdmBase.so Graphics Lines
activeRectangleClass $(EDMLIBS)/libEdmBase.so Graphics Rectangle
activeCircleClass $(EDMLIBS)/libEdmBase.so Graphics Circle
activeArcClass $(EDMLIBS)/libEdmBase.so Graphics Arc
activeXTextClass $(EDMLIBS)/libEdmBase.so Graphics Static Text
BTW, I have commented slaclib because of the build error:
../xygraph.cc:2192: error: 'class ProcessVariable' has no member named 'get_short_array'
ldd  $EDMLIBS/libEdmBase.so
 libXm.so.3 => /usr/X11R6/lib/libXm.so.3 (0x005be000)
        libXt.so.6 => /usr/X11R6/lib/libXt.so.6 (0x003a6000)
        libXp.so.6 => /usr/X11R6/lib/libXp.so.6 (0x004dd000)
        libXtst.so.6 => /usr/X11R6/lib/libXtst.so.6 (0x00450000)
        libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x00226000)
cat $EDMPVOBJECTS/edmPvObjects
1
EPICS $(EDMLIBS)/libEpics.so EPICS PV
ldd  $EDMLIBS/libEpics.so
lib114135a4-6f6c-11d3-95bc-00104b8742df.so => /home/zhangyl/epics/extensions/lib/linux-x86/lib114135a4-6f6c-11d3-95bc-00104b8742df.so (0x0050c000)
        libcfcaa62e-8199-11d3-a77f-00104b8742df.so => /home/zhangyl/epics/extensions/lib/linux-x86/libcfcaa62e-8199-11d3-a77f-00104b8742df.so (0x00616000)
        libca.so => /home/zhangyl/epics/base-3.14.9/lib/linux-x86/libca.so (0x00aa8000)
        libCom.so => /home/zhangyl/epics/base-3.14.9/lib/linux-x86/libCom.so (0x00df5000)
Zhang Yuliang
> -----原始邮件-----
> 发件人: "John William Sinclair" <[email protected]>
> 发送时间: 2012年7月12日 星期四
> 收件人: [email protected]
> 抄送:
> 主题: Re: EDM Segmentation fault
> Zhang,
> This may be a configuration issue. Examine the following environment variables and
> make sure the values are reasonable. By reasonable I mean make sure various files actually
> do reside in the referenced locations, make sure ldd doesn't report any inconsistencies, etc.
> See the examples below for some diagnostics.
> EDMOBJECTS
> This holds the directory in which the file edmObjects resides.
> For one of my installations, this is /epics/edmRuntime/config-1-12-66.
> Doing cat /epics/edmRuntime/config-1-12-66/edmObjects gives
> 35
> In this case, I have also set EDMLIBS to /epics/edmRuntime/lib-1-12-66. Your file
> will not reference EDMLIBS.
> At this point I could do ldd /epics/edmRuntime/lib-1-12-66/libEdmBase.so which gives:
>         linux-gate.so.1 =>  (0x0082e000)
>         libXm.so.3 => /usr/X11R6/lib/libXm.so.3 (0x00111000)
>         libXt.so.6 => /usr/X11R6/lib/libXt.so.6 (0x00e78000)
> EDMPVOBJECTS
> This holds the directory in which the file edmPvObjects resides.
> Doing cat /epics/edmRuntime/config-1-12-66/edmPvObjects gives
> 4
> LOC $(EDMLIBS)/libLoc.so Local PV
> CALC $(EDMLIBS)/libCalc.so Calculation PV
> DB $(EDMLIBS)/libExtra/libDb.so MySql Database PV (readonly)
> At this point I could do ldd /epics/edmRuntime/lib-1-12-66/libEpics.so which gives:
>         linux-gate.so.1 =>  (0x00cd1000)
>         lib114135a4-6f6c-11d3-95bc-00104b8742df.so => /util/lib114135a4-6f6c-11d3-95bc-00104b8742df.so (0x0098c000)
>         libcfcaa62e-8199-11d3-a77f-00104b8742df.so => /epics/edmRuntime/lib-1-12-66/libcfcaa62e-8199-11d3-a77f-00104b8742df.so (0x0080b000)
>         libca.so => /epics/supTop/R3.14.6/base-3.14.6/lib/linux-x86/libca.so (0x00d4c000)
> Try this before generating a core file and let me know if you need additional assistance.
> John Sinclair
> On 07/12/2012 03:22 AM, Zhang Yuliang wrote:
> > Hello all,
> > I am trying to install EDM-1-12-78 on a Redhat 4.8 32 bit machine and am able to build it successfully. However, when I try to create a new edl file or open an existing edl file , the EDM crashes with the error of "Segmentation fault".
> > How to solve this issue?
> > thanks and regards,
> > Zhang Yuliang
Re: EDM Segmentation fault John William Sinclair
EDM Segmentation fault Zhang Yuliang
Prev: RE: EPICS channel access performance test Hill, Jeff
Next: Re: Re: EDM Segmentation fault Zhang Yuliang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EDM Segmentation fault John William Sinclair
