Subject: RE: asynPortDriver
To: "Szalata, Zenon M." <[email protected]>
Date: Fri, 20 Jul 2012 01:10:08 +0000
Hi Zen,
What is the diagnostic mechanism you are using to determine that the counter has incremented by 2?  Is there a possibility that the waveform record is actually processing every callback OK, but that arrays are being dropped between the waveform record and whatever diagnostic client you are running?
Sent: Thursday, July 19, 2012 5:23 PM
To: Mark Rivers
Cc: [email protected]; Williams Jr., Ernest L.
Hi Mark,
I modified my version 2 asynPortDriver based device driver so that now it:
1. in ISR (at interrupt level) it read data from all 16 channels and sends the data by message queue.
2. In a high priority thread the data is received from the message queue, unpacked, and posted as an array.
    The unpacked data are put into an array where the first element is a counter, which is incremented in the
    data unpacking thread, and elements 1 through 16 are the ADC values.
In the db layer I still see missing data.  Once in a while the counter value, which is the first element in the data array, is larger by 2 than the previous counter value.  The test is done at 100Hz.
The version 3 of the device driver, which is not using asyn, does not exhibit this behavior.  In fact I can run the system with a trigger rate of up to 400Hz before it starts falling apart.  Since I have a device driver that works (version 3) I could just use it and move on.  But at this point I am still reluctant to just abandon the asynPortDriver version.  Can you think of some tests that could help understand what is causing this problem?
Zen
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Sunday, July 15, 2012 6:59 PM
> To: Szalata, Zenon M.
> Hi Zen,
> > In the first version of the device driver, I saw the effect that Kevin
> > Tsubota described in his reply to my email. This is what he said:
> > "At Keck we ran into a similar problem where we weren't seeing all the
> > events we expected with a different driver and it turned out to be that ASYN
> only posts on change."
> OK, there are 3 parts to my reply about that:
> 1) This is not an issue with ASYN in general, it is specific to asynPortDriver.
> 2) A future version of asynPortDriver should have a variant of the setXXXParam
> that takes a "force" flag, i.e.
> setIntegerParam(addr, myParam, value, forceCallback) which will force a
> callback the next time callParamCallbacks(addr) is called, even if the value has
> not changed.
> 3) Meanwhile it is trivial to force such behavior in the current version by doing
> setIntegerParam(addr, myParam, value+1); setIntegerParam(addr, myParam,
> value);
> This will fool the parameter library into thinking that the value has changed so it
> will do the callback on "value".  The overhead of doing the additional call to
> setIntegerParam is insignificant.
> > In all three version of the device driver The data is read out at
> > interrupt level, which is needed to clear the interrupt.  Then I
> > schedule a callback to continue processing the data.  This consists of
> unpacking the data  words into various components.
> I would have to see your code, but what you are doing sounds dangerous.
> What if a second interrupt occurs before the callback occurs to process the
> first?  If your data is not put in a queue, then you risk missing data.  In my Ip330
> and ipUnidig drivers I send the data from the interrupt service routine to the
> thread that will do callbacks via an epicsMessageQueue.  Then even if the
> thread that does callbacks momentarily falls behind I will not lose data unless
> the message queue overflows, and I have a flag to signal if that occurs.
> Mark
> From: Szalata, Zenon M. [[email protected]]
> Sent: Sunday, July 15, 2012 8:20 PM
> To: Mark Rivers
> Hi Mark,
> In the first version of the device driver, I saw the effect that Kevin Tsubota
> "At Keck we ran into a similar problem where we weren't seeing all the events
> we expected with a different driver and it turned out to be that ASYN only
> posts on change."
> In all three version of the device driver The data is read out at interrupt level,
> which is needed to clear the interrupt.  Then I schedule a callback to continue
> processing the data.  This consists of unpacking the data words into various
> components.
> In the case of the first version of the device driver, the callback requests to
> process the records are done in a for loop.  Perhaps I have abandoned the first
> version too quickly.
> Anyway it was clear to me that it would be better to bundle the trigger number
> and data from all ADC channels and pass that to the db layer.
> I will modify the C subroutine of the subroutine record to also print a message
> when the current gate number is less than the previous value.
> Thanks,
> Zen
> > Sent: Sunday, July 15, 2012 3:19 PM
> > How are you passing the data from your interrupt service routine to
> > the thread that is calling callParamCallbacks()?  Are you using a
> > mechanism with a queue, like an epicsMessageQueue?
> > I'd like to understand why "the order of record processing is somewhat
> > random" in method 1.  I would think that it would be deterministic
> > because there is only 1 callback thread that is processing all the
> > records in the order in which the callback requests were issued, which
> > I assume your driver does in a loop like:
> > for (i=0; i<16; i++) {
> >   callParamCallbacks(i);
> > Mark
> > Sent: Sunday, July 15, 2012 12:15 PM
> > To: Mark Rivers
> > Subject: asynPortDriver
> > Hi Mark,
> > I am trying to understand why my device driver for a CAEN VME gated
> > ADC module, which is based on asynPortDriver class works incorrectly.
> > The module has 16 ADC channels and is setup to generate an interrupt
> > for each gate signal.  The interrupt triggers data readout and record
> > processing.  For testing, the trigger/gate rate is 100 Hz.  The device
> > driver maintains a gate counter, which gets incremented each time the data
> is processed.
> > So far I have three versions of the device driver.
> > 1. In this version I have 16 I/O Intr scanned ai records.  The gate
> > counter is pushed to a longin record.
> >     This version has the problem that the order of record processing
> > is somewhat random and the IOC
> >     using this VME module requires the processing to be deterministic.
> > To overcome this difficulty,
> >    I wrote the second version.
> > 2. In this version I pack the gate counter and all 16 ADC channel
> > values into an array and this array gets
> >     pushed to a waveform record.  Then, the data gets distributed to
> > ai records using  sub array records.
> >    This part works fine.  I have subroutine record which is processed
> > each time the data waveform record
> >    is processed.  It checks for missing triggers, by expecting that
> > the gate counter value for this data array
> >    is larger by 1 than the previous one.  This is where the device
> > driver code seems to fail.
> >    I let the IOC run for a bit over 35 hours.  More precisely the time
> > corresponds to 12700898 triggers.
> >    During this time the subroutine record reported 42 missing
> > triggers.  They occurred spread out
> >    throughout the run nearly but not equally spaced in time. I have a
> > simple print statement
> >    in the C routine which prints a few numbers.  These numbers tell me
> > that the trigger incremented by 2.
> >    I just looked at the logic in the C routine and I see that I am not
> > printing messages when the new gate
> >    counter is less than the previous one.  So it is possible that from
> > time to time the waveform record gets
> >    the data out of order.  It is also possible, but I think unlikely,
> > that from time to time the data is lost.
> > 3. This version of the device driver is non-asyn.  It consists of two
> > parts, device support and record support.
> >     I wrote it, by taking the second version of the device driver and
> > replaced the asynPortDriver part with
> >    device support.  Also, I created a new version of the IOC, by
> > taking the IOC which used the second version of
> >    the device driver and modifying the db files and the st.cmd file as
> > needed.  I ran this IOC version
> >   overnight, so far it has processed 4 and half million triggers and
> > not a single missed trigger.
> > I wonder if the behavior observed using the second version of the
> > device driver is to be expected?
> > Does it mean, that for some applications the asynPortDriver approach
> > to device driver implementation might be not appropriate?
> > Zen
RE: asynPortDriver Szalata, Zenon M.
RE: asynPortDriver Mark Rivers
Prev: RE: asynPortDriver Mark Rivers
Next: Clarification required in SNL manta santosh aditya santosh_aditya
Next: RE: asynPortDriver Szalata, Zenon M.
