1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with the basic example
Cc: [email protected]
Date: Tue, 31 Jul 2012 10:13:09 -0400
Hi Bruno,
EPICS uses the period symbol to separate record from field. For example:
dbpr myRecord.VAL
I think you should get rid of the period in your record name. You can probably do this in the line in your st.cmd file that says:
dbLoadRecords "db/dbSubExample.db", "user=bruno.martins"
Change 'bruno.martins' to 'bruno'.
- Mike J
- JLab
On Tue, Jul 31, 2012 at 10:01 AM, Bruno Seiva Martins <[email protected]> wrote:
Hi
I don't know if this is the place for a begginer question, but here I go.
I'm starting out using EPICS, following basic tutorials. I was able to compile epics base without a problem. Then I created the example IOC using makeBaseApp.pl.
Everything went fine, and I got the IOC to run:
epics> dbl
bruno.martinsHost:aiExample
bruno.martinsHost:aiExample1
bruno.martinsHost:aiExample2
bruno.martinsHost:aiExample3
bruno.martinsHost:aSubExample
bruno.martinsHost:calc1
bruno.martinsHost:calc2
bruno.martinsHost:calc3
bruno.martinsHost:calcExample
bruno.martinsHost:calcExample1
bruno.martinsHost:calcExample2
bruno.martinsHost:calcExample3
bruno.martinsHost:compressExample
bruno.martinsHost:subExample
bruno.martinsHost:xxxExample
But then, when I tried to get more details about one of these PV's, I got:
epics> dbpr bruno.martinsHost:aiExample3
Record 'bruno.martinsHost:aiExample3' not found
I got this message for every PV I tried, and I don't really know what went wrong, since the PV's are being listed...
Thanks in advance!
Bruno Seiva Martins
Problem with the basic example Bruno Seiva Martins
Prev: Problem with the basic example Bruno Seiva Martins
Next: Re: Problem with the basic example Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
