Subject: Re: Problem with the basic example
To: <[email protected]>
Date: Tue, 31 Jul 2012 16:46:09 +0200
Hi Bruno
To slightly elaborate Michael's answer: macro substitution can be performed
early (during make) or late (when loading files) or both (i.e. parts of the
substitution are done early, another part late). The Makefile specifies
which are done early, the startup file which are done late.
Cheers
Ben
On Tuesday, July 31, 2012, Michael Johnson wrote:
> Bruno,
> Good catch on the *.substitutions files.
> The Make process is also responsible for copying over certain source
> files to IOC resource folders. "db/" holds your database and
> substitution files. A quick 'find' should show you more than one copy,
> something like:
> ./db/user.substitutions
> ./db/userHost.substitutions
> ./testOneApp/Db/user.substitutions
> ./testOneApp/Db/userHost.substitutions
> So maybe the file you were editing (App/Db/) was not the one you were
> loading (db/).
> - Mike
> - JLab
> On Tue, Jul 31, 2012 at 10:30 AM, Bruno Seiva Martins
> [email protected]>wrote:
> > Changing the st.cmd file got only two records to change:
> > epics> dbl
> > bruno.martinsHost:aiExample
> > bruno.martinsHost:aiExample1
> > bruno.martinsHost:aiExample2
> > bruno.martinsHost:aiExample3
> > bruno:aSubExample
> > bruno.martinsHost:calc1
> > bruno.martinsHost:calc2
> > bruno.martinsHost:calc3
> > bruno.martinsHost:calcExample
> > bruno.martinsHost:calcExample1
> > bruno.martinsHost:calcExample2
> > bruno.martinsHost:calcExample3
> > bruno.martinsHost:compressExample
> > bruno:subExample
> > bruno.martinsHost:xxxExample
> > I suspected the files user.substitutions and userHost.substitutions
> > were the responsibles, changed "bruno.martinsHost" and "bruno.martins"
> > to "bruno", ran st.cmd again, same results.
> > Only when I recompiled all changes took effect:
> > epics> dbl
> > bruno:ai1
> > bruno:ai2
> > bruno:ai3
> > bruno:aiExample
> > bruno:aiExample1
> > bruno:aiExample2
> > bruno:aiExample3
> > bruno:aSubExample
> > bruno:calc1
> > bruno:calc2
> > bruno:calc3
> > bruno:calcExample
> > bruno:calcExample1
> > bruno:calcExample2
> > bruno:calcExample3
> > bruno:compressExample
> > bruno:subExample
> > bruno:xxxExample
> > Is this recompilation really necessary? The way I see, the st.cmd file
> > is a script that loads these *.substitutions files and parse them
> > dinamically, but seems not quite like that.
> > On Tue, Jul 31, 2012 at 11:19 AM, Benjamin Franksen <
> > [email protected]> wrote:
> >> On Tuesday, July 31, 2012, Bruno Seiva Martins wrote:
> >> > I don't know if this is the place for a begginer question, but here
> >> > I
> >> go.
> >> It is, and you are welcome.
> >> > I'm starting out using EPICS, following basic tutorials. I was able
> >> > to compile epics base without a problem. Then I created the example
> >> > IOC using makeBaseApp.pl.
> >> > Everything went fine, and I got the IOC to run:
> >> > epics> dbl
> >> > bruno.martinsHost:aSubExample
> >> > bruno.martinsHost:subExample
> >> > But then, when I tried to get more details about one of these PV's,
> >> > I got:
> >> > epics> dbpr bruno.martinsHost:aiExample3
> >> > Record 'bruno.martinsHost:aiExample3' not found
> >> > I got this message for every PV I tried, and I don't really know
> >> > what went wrong, since the PV's are being listed...
> >> As otehr have noted, dot ('.') is not allowed in record names.
> >> However, your db file should have been rejected when loading, and not
> >> when trying to find the record. So this is actually a bug in EPICS
> >> base.
> >> Cheers
> >> Ben
> > Bruno Seiva Martins
> > Departamento de Computação
> > Universidade Federal de São Carlos - UFSCar
Attachment: signature.asc
Description: This is a digitally signed message part.
Problem with the basic example Bruno Seiva Martins
Re: Problem with the basic example Bruno Seiva Martins
Re: Problem with the basic example Michael Johnson
Prev: Re: Problem with the basic example Michael Johnson
Next: Re: Problem with the basic example Andrew Johnson
Next: CSS BOY Dynamic Strip Charts with Macros Alex Dunn
