Subject: Re: EPICS Base version 3.15.0.1 released
To: [email protected]
Date: Sun, 12 Aug 2012 18:33:35 +0200
Hi Andrew,
> In this case the relevant GnuMake code is found in Base/configure/RULES.Db and
> it says that if you provide a rule to generate a file named in DB you have to
> have a parallel rule that generates the associated dependency file.
Thank you for clarification. After generating the dependency files with
the make rules you suggested everything works like a charm. This
includes the new macro substitution function with dbLoadTemplate :-)
Maybe you want to mention this feature in the release notes? I think it
could be quite useful for some people.
Great work - thanks to you and all the other developers!
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
EPICS Base version 3.15.0.1 released Andrew Johnson
Re: EPICS Base version 3.15.0.1 released Martin Konrad
Re: EPICS Base version 3.15.0.1 released Andrew Johnson
Prev: RE: Building EPICS on Mac Mark Rivers
Next: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Prev: Re: EPICS Base version 3.15.0.1 released Andrew Johnson
Next: Re: EPICS Base version 3.15.0.1 released Tim Mooney
