Subject: Re: Building EPICS on Mac
Date: Mon, 13 Aug 2012 10:14:55 -0500
On 8/11/12 11:53 AM, Mark Rivers wrote:
> I figured it out.
> It works if I build with clang and also uncomment the line for GNU_LDLIBS_YES =
> # Uncomment the followings lines to build with CLANG instead of GCC.
> CC             = clang
> CCC            = clang++
> GNU_LDLIBS_YES =
> It does not work with the default version of CONFIG_SITE.Common.darwin-x86
EPICS Base developers: I think Clang should be the default for
darwin instead of GCC.  I'm not pushing this, but at some point
this should probably be changed.  The Mac OS X developer tools
do not come with GCC by default anymore; the default is Clang.
Lewis
Re: Building EPICS on Mac Andrew Johnson
Building EPICS on Mac Mark Rivers
RE: Building EPICS on Mac Mark Rivers
Prev: Re: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Next: Re: Cross-compilation, static build, etc J. Lewis Muir
Prev: RE: Building EPICS on Mac Mark Rivers
Next: Re: Building EPICS on Mac Andrew Johnson
