Subject: Re: EPICS Base version 3.15.0.1 released
Cc: [email protected]
Date: Wed, 15 Aug 2012 11:46:10 -0500 (CDT)
Andrew,
If I change all instances of prompt(abc) to prompt("abc"), and initial(1) to initial("1"), both vdct and the ioc seem fine with the resulting .dbd file.
Tim
----- Original Message -----
To: "Andrew Johnson" <[email protected]>
Sent: Tuesday, August 14, 2012 1:15:44 PM
Andrew,
The new iocxxx.dbd file is not accepted by vdct.
I was able to get an apparently acceptable .dbd file by deleting lines of the form
    prompt(abc)
and
    initial(1)
although vdct issues the following warning:
    Warning: $(P)$(R):mode -> DTYP field needs to be defined before two fields INP and OUT...
which I'll guess is no longer needed.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Re: EPICS Base version 3.15.0.1 released Andrew Johnson
Re: EPICS Base version 3.15.0.1 released Tim Mooney
Prev: Re: JCas Ralph Lange
Next: Re: Fwd: Re: OPC with binary out records pthomas
Prev: Re: EPICS Base version 3.15.0.1 released Tim Mooney
Next: Re: EPICS Base version 3.15.0.1 released Andrew Johnson
