Subject: Re: EPICS Base version 3.15.0.1 released
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 21 Aug 2012 11:56:05 +0200
Dirk Zimoch wrote:
Dirk Zimoch wrote:
Installing to a different INSTALL_LOCATION fails:
make[3]: Entering directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom/O.linux-x86'
perl -CSD ../../../src/libCom/env/bldEnvData.pl  ../../../configure
Can't locate EPICS/Path.pm in @INC (@INC contains: ../../../lib/perl /usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.8/i386-linux-thread-multi /usr/lib/perl5/5.8.8 .) at ../../../src/libCom/env/bldEnvData.pl line 20. BEGIN failed--compilation aborted at ../../../src/libCom/env/bldEnvData.pl line 20.
make[3]: Leaving directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/afs/psi.ch/group/8431/dirk/cvs/base-3.15.0.1/src'
make: *** [src.install] Error 2
Without setting INSTALL_LOCATION installation succeeds.
Dirk
The problem can be fixed by changing the definition of the macro PERL in configure/CONFIG_COMMON to
PERL = perl -CSD -I $(INSTALL_PERL_MODULES)
When building modules (here asyn4-19) against an EPICS base in an INSTALL_LOCATION, the header files in $(EPICS_BASE)/include/os/$(OS_CLASS) are not found. With an EPICS base without INSTALL_LOCATION it works.
Dirk
Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
EPICS Base version 3.15.0.1 released Andrew Johnson
Re: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Prev: Re: Building EPICS on Mac Andrew Johnson
Next: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Prev: Re: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
