1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 3.15 generates strange shared library names
To: EPICS <[email protected]>
Date: Wed, 22 Aug 2012 15:16:01 +0200
Dirk Zimoch wrote:
When EPICS 3.15 builds Linux shared libraries, either from base or other modules, it adds a . after the .so extension:
Examples:
libCap5.so.
libasyn.so.
libstream.so.
Dirk
The problem is in configure/os/CONFIG.Common.UnixCommon.
instead of
SHRLIB_SUFFIX = $(SHRLIB_SUFFIX_BASE).$(SHRLIB_VERSION)
which generates .so. when SHRLIB_VERSION is empty
better use
SHRLIB_SUFFIX = $(SHRLIB_SUFFIX_BASE)$(addprefix .,$(SHRLIB_VERSION))
The same for LOADABLE_SHRLIB_SUFFIX
Dirk
Re: EPICS 3.15 generates strange shared library names Andrew Johnson
EPICS 3.15 generates strange shared library names Dirk Zimoch
Prev: EPICS 3.15 generates strange shared library names Dirk Zimoch
Next: EDM & motif Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS 3.15 generates strange shared library names Andrew Johnson
