Subject: Re: dbd file parser in 3.15 is too strict
To: [email protected]
Date: Wed, 22 Aug 2012 10:27:30 -0500
Hi Dirk,
On 2012-08-22 Dirk Zimoch wrote:
> The dbd file parser does not accept empty strings as initial values:
> Syntax error in 'initial()'
> Context: field(PORT, DBF_STRING) in recordtype(asyn) in file
> '../O.Common/streamApp.dbd'
> The field in question is:
>      field(PORT,DBF_STRING) {
>          prompt("asyn port")
>          promptgroup(GUI_INPUTS)
>          special(SPC_MOD)
>          interest(1)
>          initial("")
>          size(40)
> The problem lies in lib/perl/DBD/Parser.pm where $string does not accept
> empty strings.
Actually the problem lies in DBD/Output.pm; dbdExpand.pl was not including
quotes when writing out empty field attribute values in the expanded file.
The other DBD file parsers (in dbStaticLib and VDCT) aren't going to accept a
field attribute spelled
	initial()
either, it needs to be
	initial("")
although in practice this attribute does nothing and can be deleted since an
empty string is the default anyway.
I've just added another patch to the Known Problems page for this.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
dbd file parser in 3.15 is too strict Dirk Zimoch
Prev: Re: EPICS 3.15 generates strange shared library names Andrew Johnson
Next: Re: EPICS Base version 3.15.0.1 released Andrew Johnson
Prev: dbd file parser in 3.15 is too strict Dirk Zimoch
Next: EPICS2012 registration 이은희
