Subject: Motor Record 6-5-2 backlash issue?
To: <[email protected]>
Cc: Márcio Paduan Donadio <[email protected]>
Date: Thu, 23 Aug 2012 18:25:21 -0300
        Hi folks.
    When BACC = ACCL and BVEL = VELO and BDST > 0, I see the movement as I expect: for positive movements, no backlash correction; for negative movements a backlash correction.
    But when BACC != ACCL or BVEL != VELO and BDST > 0, something different happens: for positive movements the motor stops before the target and moves again by BDST to hit the target.
    Is this the correct behavior?
Engenheiro de Computação - Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron ? (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
+ 55 (19) 3512-3520 - [email protected]
www.lnls.br
Re: Motor Record 6-5-2 backlash issue? Kurt Goetze
Prev: Problem with medmfonts.ali running under Ubuntu 1204 Ivan
Next: Re: Motor Record 6-5-2 backlash issue? Kurt Goetze
Prev: Re: Problem with medmfonts.ali running under Ubuntu 1204 Ivan Kohler
