Subject: font init failed
To: Tech Talk <[email protected]>
Date: Wed, 12 Sep 2012 13:51:33 -0500
I have a new machine with a new SLF 6.2 installation on a 64-bit machine.  I have the
same "Font init failed - abort" message as previously mentioned here. I found message
00357 as a possible solution, but alas, I have no /etc/X11/xorg.conf file.
Is there a new solution to this problem?
Pierrick
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Re: font init failed Andrew Johnson
Prev: autosave R5-0 mooney
Next: Re: font init failed Andrew Johnson
