Subject: Re: waveform changes using subArray
To: Tim Mooney <[email protected]>
Cc: Tech Talk <[email protected]>
Date: Fri, 14 Sep 2012 14:30:31 +0200
Ned, Tim thank you for suggestions. We'll try out solution ASAP.
Best Regards,
Hinko
On 09/13/2012 06:33 PM, Tim Mooney wrote:
Hinko,
You could do this with the acalcout (array calcout) record in the calc module. (http://www.aps.anl.gov/bcda/synApps/calc/aCalcoutRecord.html)
If .BB is the M-element replacement array, you can read the waveform into the .AA field, overwrite with M elements from .BB, beginning at index N, and write the result back to the waveform record, by configuring the record like this:
.A = M
.B = N
.INAA = "waveform.VAL NPP"
.CALC = "AA[0,B-1]+(BB[0,A-1]>>B)+(AA[A+B,-1]>>A+B)"
.OUT = "waveform.VAL PP"
Tim
----- Original Message -----
To: "Tech Talk" <[email protected]>
Sent: Thursday, September 13, 2012 6:59:05 AM
Subject: waveform changes using subArray
We are trying to support a modification of long array (i.e. more than
500 integer values) seen as a waveform in EPICS IOC. Lets say that it is
possible and valid for user to change only one or two values from this
array. By using waveform user needs to get all 500 integers locate the
one she wants to change, do the modification, store complete array back.
Using subArray to make a "window" into waveform sounded like a good
solution, but as I just read in the docs, subArray does not support
value writing back to the waveform.
Can this be done in some other manner? The goal here would be to allow
user to get/see/change/set only the part of waveform, that shes
interested in.
Thank you!
Hinko
Hinko Kocevar
Software development engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
E-mail: [email protected]
http://www.i-tech.si
The information transmitted is intended solely for the
addressee and may contain confidential and/or privileged
information. Any review, retention, disclosure or other use
by persons other than the intended recipient is prohibited.
If you received this in error, please notify the sender and
delete all copies.
Re: waveform changes using subArray Andrew Johnson
Re: waveform changes using subArray Tim Mooney
Prev: Re: Protocol files for CAEN SYS5527/A4528 Ethernet module Burkhard Kolb
Next: Re: access record info from asyn Hinko Kocevar
Prev: Re: waveform changes using subArray Tim Mooney
Next: Re: waveform changes using subArray Andrew Johnson
