Subject: aSub record : adding arguments
Date: Fri, 14 Sep 2012 10:07:01 -0400
Hi all,
Adding arguemnts to the aSub record would facilitate the usage of the subroutine to be more globally generic and versatile. The arguments will be used for the subroutine. For example, I modified the file src/rec/aSubRecord.dbd as the following to achieve the goal in my project. I wish that the addition of the arguments in aSub record could be considered in the EPICS 3.14.x branch in addition to the higher one such as 3.15.
Any pointer regarding what I missed or any consideration ?
diff -Naur  aSubRecord.dbd.orig aSubRecord.dbd
--- aSubRecord.dbd.orig    2011-04-26 16:40:09.000000000 -0400
+++ aSubRecord.dbd    2012-09-14 09:38:24.086888851 -0400
@@ -11,6 +11,28 @@
 recordtype(aSub) {
     include "dbCommon.dbd"
+# ARG1,ARG2,ARG3,and ARG4 added on 9/10/12
+    field(ARG1,DBF_ULONG) {
+        prompt("Subroutine Argument1")
+        promptgroup(GUI_CONVERT)
+        pp(TRUE)
+    field(ARG2,DBF_ULONG) {
+        prompt("Subroutine Argument2")
+        pp(TRUE)
+    field(ARG3,DBF_ULONG) {
+        prompt("Subroutine Argument3")
+        pp(TRUE)
+    field(ARG4,DBF_ULONG) {
+        prompt("Subroutine Argument4")
+        pp(TRUE)
+# end of ARG1,ARG2,ARG3,and ARG4 add on
     field(VAL,DBF_LONG) {
         prompt("Subr. return value")
         asl(ASL0)
Kate Feng
Re: aSub record : adding arguments Andrew Johnson
Prev: Re: access record info from asyn Hinko Kocevar
Next: Re: waveform changes using subArray Andrew Johnson
Prev: Re: Installing MEDM on UBUNTU 10.04.1 LTS x64 Pete R. Jemian
Next: Re: aSub record : adding arguments Andrew Johnson
