Subject: Re: ISEG EHS device support on the Raspberry Pi Computer
To: "Mark Rivers" <[email protected]>
Cc: EPICS tech talk <[email protected]>
Date: 18 Sep 2012 22:05:35 +0200
Hi Mark,
Am 18.09.2012 18:57, schrieb Mark Rivers:
Hi Florian,
I am not sure I fully understand what you are trying to do.
Is the following correct?
1) StreamDevice writes strings on the asynOctet interface.  All device support could be done with StreamDevice.
This is true.
2) These strings are not directly compatible with your hardware.  You need to modify these strings before sending them to your hardware.
my hardware uses CAN frames. So I have to convert the strings from StreamDevice to this:
struct can_frame {
  uint32_t can_id;   // 11/29 bit identifier + RTR, IDE and Error flags
  uint8_t   dlc;
  uint8_t   data[8];
3) Your hardware is compatible with the drvAsynSerialPort and/or drvAsynIPPort asyn drivers at the lowest level.
I guess my hardware is not compatible to drvAsynSerialPort and/or drvAsynIPPort, but this I have to check.
What I'm currently trying to do is writing an asynPortDriver for my hardware, because in your first mail you wrote:
If you use asynPortDriver as your base class most of the details asyn are hidden from you.  You don't need to worry about
registering the port, registering the interfaces, how to do callbacks, etc."
Therefore I thought this would be a good approach...
Best regards,
Florian
If all 3 of these statements is true, then this is a perfect candidate for implementation as an "asynInterpose" layer.  You write an asynInterpose driver that takes asynOctet strings from StreamDevice, modifies those strings, and passes them on to the underlying serial or IP driver.
This is exactly what is done with the Modbus driver.  It takes protocol-independent strings from the Modbus driver layer and adds the protocol headers for the Modbus TCP, Modbus RTU, or Modbus ASCII protocols.  These strings are then passed to the standard asyn serial or TCP drivers.  On input it strips these headers before passing the strings up to the Modbus driver.
-----Original Message-----
Sent: Tuesday, September 18, 2012 3:54 AM
To: Mark Rivers
Cc: EPICS tech talk
Hi Mark,
I started writing my asyn Driver using asynPortDriver as base class.
StreamDevice uses asynOctet to interface the driver, so I guess I need
to implement the methods readOctet and writeOctet and I also need (at
least) one
Octet-parameter for my class, right?
I'm still thinking a custom device support for our iseg hv would be more
feasible than using StreamDevice. So I'd like to continue this approach
as well.
  From the first look I would say the best way to interface the asyn driver
would be asynGenericPointer.
Is it possible to use this interface for asynPortDriver?
I guess I would have to implement set and get methods for this parameter
type
for the paramList class asynPortDriver uses?
Best regards,
Florian
On 09/10/2012 04:53 PM, Mark Rivers wrote:
Hi Florian,
I would encourage you to consider whether you should write device support at all.  I am copying Bruno on this as well, because I meant to respond to his earlier thread "aiRecord conversion" with a similar comment.
Instead of writing device support you should really consider writing an asyn driver.  If you do that then device support is done for you, and you don't need to worry about all the details of how records interact with device support.  Writing an asyn driver is actually quite easy.  There are many advantages:
- Support for synchronous and asynchronous devices requires a single-bit change in your driver's registration.
- Support for I/O Intr scanned records is easy.
- The device support is already debugged.
- You get the asynTrace capabilities for standard debugging support.
- You free the developer to use whatever records they want, rather than only the records you support in your device support.
- If you use asynPortDriver as your base class most of the details asyn are hidden from you.  You don't need to worry about registering the port, registering the interfaces, how to do callbacks, etc.
In your case you might also be able to use StreamDevice.  I don't know enough about the CAN interface to know if this is feasible or not.
There are lots of examples of asyn drivers, including testAsynPortDriverApp in the asyn package, the Modbus driver, and many other drivers in the synApps package.
From: [email protected] [mailto:[email protected]] On Behalf Of Florian Feldbauer
Sent: Monday, September 10, 2012 6:24 AM
To: EPICS tech talk
Subject: ISEG EHS device support on the Raspberry Pi Computer
Dear all,
at Bochum university, we have developed a CAN bus interfacefor the
Raspberry Pi computer [1]
using the SJA1000 stand-alone CAN controller.
We are using this interface to control the high voltage power supply modules
EHS 8 620p-F and EHS 8 210p-F from ISEG [2] via the crate controller ECH238.
I have programmed a device support for these high voltage modules based
on our Raspberry Pi Can interface.
You can find the sources for the device support as well as the schematic
of our CAN interface on github:
https://github.com/ffeldbauer/epics_RPi_can
I will upgrade this repository with a device support for our Wiener VME
crate, and some custom hardware.
The VME crate has an CAN interface which can be used to read out
voltages, currents, temperature and status of the crate.
Up to now the driver support in EPICS is only synchronous. Is there any
documentation on how to program an
asynchronous driver support? For some other devices we would need an
asynchronous support.
Best regards,
Florian
[1] http://www.raspberrypi.org/
[2] http://www.iseg-hv.com/en/products/product-details/product/21/
RE: ISEG EHS device support on the Raspberry Pi Computer Mark Rivers
ISEG EHS device support on the Raspberry Pi Computer Florian Feldbauer
Re: ISEG EHS device support on the Raspberry Pi Computer Florian Feldbauer
Prev: RE: ISEG EHS device support on the Raspberry Pi Computer Mark Rivers
Next: RE: ISEG EHS device support on the Raspberry Pi Computer Mark Rivers
