Subject: Re: Bug in devLibVMEImpl.h in 3.14.12 and 3.15
To: [email protected]
Date: Wed, 19 Sep 2012 09:57:29 -0400
Yup, this was an oversight on my part.  As a workaround:
#if EPICS_VERSION==3 && EPICS_REVISION==14 && EPICS_MODIFICATION<12
typedef devLibVirtualOS osTableType; /* old name */
#else
typedef devLibVME osTableType; /* new name */
#endif
Also note that a function pointer for devInterruptInUseVME() was added to the table definition as well.
Michael
On 9/18/2012 3:35 AM, Dirk Zimoch wrote:
The devLibVMEImpl.h defines a backward compatibility macro:
#ifndef NO_DEVLIB_COMPAT
#  define pdevLibVirtualOS pdevLibVME
#endif
However, this is only the name of the global variable which has changed. The type of that variable has changed too. In order to provide real backward compatibility, the following additional macro is needed.
#  define devLibVirtualOS devLibVME
(or use a typedef)
Dirk
Bug in devLibVMEImpl.h in 3.14.12 and 3.15 Dirk Zimoch
Prev: Re: ISEG EHS device support on the Raspberry Pi Computer Florian Feldbauer
Next: Doxygen and EPICS build system Ralph Lange
Prev: Bug in devLibVMEImpl.h in 3.14.12 and 3.15 Dirk Zimoch
