1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Doxygen and EPICS build system
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Thu, 20 Sep 2012 11:44:25 +0200
Thanks, Andrew and Benjamin!
I ended up deciding to make the generated doc part of the sources.
Which is bad, I know, but IMHO not as bad as forcing people to have root
access and install a fat toolchain (Doxygen/LaTeX), just because they
want to look at the manual.
The regular build just installs the existing stuff, while the new make
target "doxy" creates a new version of the documentation from the source
files.
To do that I added in .../Makefile:
INSTALL_DOCS += $(INSTALL_HTML)/MCoreUtils
DOCS += MCoreUtils.pdf
$(INSTALL_DOC)/%: ../documentation/%
    $(ECHO) "Installing doc $@"
    @$(INSTALL) -d -m $(INSTALL_PERMISSIONS) $< $(INSTALL_DOC)
$(INSTALL_HTML)/%: ../documentation/%
    $(ECHO) "Installing html tree $@"
    @$(MKDIR) -p $(INSTALL_HTML)
    @$(CP) -rT $< $@
    @find $@ -type f -exec chmod $(INSTALL_PERMISSIONS) {} \;
doxy:
    @$(RMDIR) O.Common/doxy
    @$(RMDIR) documentation
    @$(MKDIR) -p documentation/MCoreUtils
    @doxygen
    @make -C O.Common/doxy/latex
    @$(CP) O.Common/doxy/latex/refman.pdf documentation/MCoreUtils.pdf
    @$(CP) -rT O.Common/doxy/html documentation/MCoreUtils
Thanks again,
~Ralph
Doxygen and EPICS build system Ralph Lange
Re: Doxygen and EPICS build system Benjamin Franksen
Prev: Re: Doxygen and EPICS build system Benjamin Franksen
Next: Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: CAC problem between RTEMS and vxWorks Wesley Moore
