1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAC problem between RTEMS and vxWorks
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 21 Sep 2012 11:37:03 -0400 (EDT)
----- Original Message -----
> From: "J. Lewis Muir" <[email protected]>
> To: "Wesley Moore" <[email protected]>
> Cc: "Jeff Hill" <[email protected]>, "Dirk Zimoch" <[email protected]>, "Benjamin Franksen"
> <[email protected]>, "EPICS tech-talk" <[email protected]>
> Sent: Friday, September 21, 2012 10:45:13 AM
> On 9/21/12 9:33 AM, Wesley Moore wrote:
> > Jeff and Dirk - thanks for getting back to me.
> > I'm familiar with some of the issues that you guys pointed out,
> > they can definitely bite you.  While double-checking your
> > suggestions I found that one of the channels that was being
> > monitored came from another vxWorks IOC (mistake on my part).
> >  Surprise, surprise...it never has any disconnect issues.
> >  Following that lead, I found that the problems seem to be
> > centered around a dynamically assigned pv in one of my two
> > sequencers.  When I hard-coded that pv assignment the problems
> > went away.  This remains consistent.  What's confusing me a bit is
> > that I use dynamic assignment in the working sequencer, I just
> > don't do any reassignments.
> > Ben - Any known issues with dynamic assignment/reassignment?
> >  Perhaps specific to RTEMS?
> Hi, Wesley.
> There have been a number of bug fixes related to pvAssign.  You
> can find these in the release notes (just search in the page for
> "pvAssign"):
>   http://www-csr.bessy.de/control/SoftDist/sequencer/Notes.html
> What version of the sequencer are you using?
> Lewis
Lewis,
I'm using 2-1-9.  Looking through all the release notes and also seq_if.c.  I'm thinking of trying to de-assign the channel between uses.
Wesley
Re: CAC problem between RTEMS and vxWorks J. Lewis Muir
Prev: Re: CAC problem between RTEMS and vxWorks J. Lewis Muir
Next: FW: BPM Screens Southern, Tim
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CAC problem between RTEMS and vxWorks Benjamin Franksen
