Subject: Re: DHCP/BOOTP configuration for EPICS with RTEMS
To: Bruno Seiva Martins <[email protected]>
Cc: [email protected]
Date: Mon, 24 Sep 2012 09:15:13 -0700
The RTEMS BOOTP/DHCP code uses code 66 to set the NFS server name and code 129 for the 'command line string' from which the EPICS startup code parses  the local mount point and remote mount path.
Eric Norum
[email protected]
Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
Re: DHCP/BOOTP configuration for EPICS with RTEMS Eric Norum
Prev: Re: Problem with using strings to access enum indices on Windows J. Lewis Muir
Next: Re: Problem with using strings to access enum indices on Windows Andrew Johnson
Prev: Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
Next: Re: DHCP/BOOTP configuration for EPICS with RTEMS Bruno Seiva Martins
