1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor record -- URIP with soft limits
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Tue, 25 Sep 2012 13:31:51 -0700
On 09/25/2012 01:01 PM, J. Lewis Muir wrote:
On 9/25/12 1:45 PM, Fong, Nia W. wrote:
We just setup our motors to use a readback link URIP, getting motor position from an external LVDT device and are running into a problem when the motor is moved to one of its soft limits.
We notice that when a motor is moved to its soft limit, it is possible for the motor to end up at a position slightly outside of its soft limit (how far out depends on how high we set the retry deadband RDBD).  As a result, the motor can no longer be moved until the soft limit it is violating is manually widened outside of the RBV value.  According to the motor record documentation, HLM uses the VAL, but it looks like it is instead using the RBV field.  Both fields would seem valid depending on the application.
Has anyone else run into this problem using URIP and the HLM and DLM?  How was it resolved?
Hi, Nia.
I've run into the same problem, but not using URIP.
Are you using "Use Encoder" ?
Seems to me that any of the "USE xxx" modes exhibit this problem.
My scenario
is like yours: I can't move the motor because it is beyond one
of the soft limits.  My workaround is to temporarily extend or
disable the soft limits, move the motor back to a position
within the original soft limits, and then restore the soft
limits.
This is a manual operation that we don't operators to have to deal with.
Of course, some sequencer could be written for automation.
If there's a better way, I'm interested in hearing it.
Well, here it seems that some code changes can be made in the motorRecord business logic to handle this case?
We are  also interested in a better solution for this problem.
Lewis
Re: Motor record -- URIP with soft limits J. Lewis Muir
Motor record -- URIP with soft limits Fong, Nia W.
Prev: Re: Motor record -- URIP with soft limits J. Lewis Muir
Next: Re: Motor record -- URIP with soft limits J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
