Subject: RE: How can I collect data values
To: "'Kai Stein'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 27 Sep 2012 14:46:30 +0000
The EPICS sscan record is designed for doing exactly this type of thing.  I will collect data into arrays in the record, and in conjunction with the saveData utility in the sscan module will write the values to a portable binary disk file.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Kai Stein
Sent: Thursday, September 27, 2012 9:44 AM
To: [email protected]
Subject: How can I collect data values
Hello,
I'm working on an automatic data analysis of electron beam (emittance
measurement with a wire scanner and a magnetic lens) with EPICS.
I get values from the hardware (self build measurement cards). The
device support put the values into a longin records (this part is fixed,
because it is already used for other applications).
I need to gather the values (will be a position and a corresponding
current) for a certain amount of time (approximately 1000 to 10000
values)  and then hand it over to a subroutine, to perform the analysis
(like fitting a curve onto the data). It should all run on a debian machine.
My problem is to collect the data with EPICS. I thought about collecting
them somehow in a waveform record, but i have no idea, how to do this by
using other records instead of the device support.
Best regards,
Kai Stein
Re: How can I collect data values Tim Mooney
RE: How can I collect data values Hu, Yong
How can I collect data values Kai Stein
Prev: How can I collect data values Kai Stein
Next: EPICS Collaboration Meeting October 2012 : Agenda update Ilyou Kim
Next: Re: How can I collect data values Tim Mooney
