Franck,
You can use a trigger PV to cause the save set to be written whenever the trigger PV posts a value.
You can do this with a monitor save set that is also monitored:
create_monitor_set("auto_settings.req",30,"P=xxx:")
create_triggered_set("auto_settings.req","xxx:myTrigger","P=xxx:")
Because the save-set name is the same in both calls, the second doesn't add a new save set, but instead adds a new method to the existing save set.
Tim
----- Original Message -----
To: [email protected]
Sent: Friday, October 5, 2012 4:55:12 AM
Subject: Triggered autosave on exit
Dear Experts, Gurus and Educated Friends
A question that probably already popped-up in the past...
If we want that when the IOC process exits (in an healthy state) because it has been requested so (i.e. not crashed), the autosave is executed before the exit ... how can that be done?
The objective is to prevent that the changes made few seconds before a "restart" are lost (a use case during tests).
And we don't want to reduce the autosave period only for this case.
Thanks!
Franck
Franck Di Maio
CODAC System Designer
CODAC Section
ITER Organization, Building 519/027, CHD, Control System Division
Route de Vinon sur Verdon - 13115 St Paul Lez Durance - France
Phone: +33 4 42 17 64 05
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
- RE: Triggered autosave on exit Mark Rivers
- Triggered autosave on exit Di Maio Franck
EPICS 3.15.0 incompatible make rules Dirk Zimoch
<2012>
2025
2026
<2012>
2025
2026
