Subject: Re: API to get list of record names
To: <[email protected]>
Date: Fri, 12 Oct 2012 03:39:41 +0200
Am Freitag, 12. Oktober 2012, 01:17:00 schrieb Andrew Johnson:
> On 2012-10-11 Rod Nussbaumer wrote:
> > Is there an API in EPICS to get a list of record names, in the way that
> > the dbl command provides?  I've looked through the developer's guide,
> > and don't see anything that looks like it to me. If not, is there
> > danger/restrictions/limits in using whatever method is used by the dbl
> > command? I haven't looked at that code yet; any pointers to where I'd
> > find it are welcome. I'll be using R3.14.12.2.
> Look at the AppDevGuide chapter on dbStaticLib, and the code for dbl itself
> (in src/db/dbTest.c IIRC but that might be wrong).
IIRC, the name of the relevant chapter in the Guide is "Static Database
Access". This describes a simple cursor-based interface to the EPICS database.
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
API to get list of record names Rod Nussbaumer
Re: API to get list of record names Andrew Johnson
Prev: Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
Next: Re: Calcout using CA output link sometimes gets INVALID severity Andrew Johnson
Prev: Re: API to get list of record names Andrew Johnson
Next: Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
