Subject: Re: Calcout using CA output link sometimes gets INVALID severity
Cc: [email protected]
Date: Fri, 12 Oct 2012 10:45:33 -0500
On 10/12/12 10:09 AM, Andrew Johnson wrote:
> Hi Lewis,
> On 2012-10-11 J. Lewis Muir wrote:
>> I've got a problem with a calcout record where, if I do a dbpf
>> after iocInit on an ao record that has a forward link to the
>> calcout record which in turn reads the ao record VAL field and
>> writes a calculated value to an ai record using a Channel Access
>> output link, sometimes the calcout record's SEVR field will be
>> INVALID, and it does not write the calculated value to the ai
>> record.  This doesn't happen every time, but I can usually get
>> it to happen within 5 tries.  If I change the output link type
>> from CA to PP, the problem goes away.  Does anyone know what's
>> wrong?
> Is the dbpf that triggers this in the IOC's startup script, or being issued
> manually?
Hi, Andrew.
It is in the IOC's start-up script.
> I'm guessing it's in the script, and I suspect what's happening
> when you get the link alarm may be that the CA link hasn't finished connecting
> up by the time the dbpf runs.  CA link processing involves several different
> threads even when the target PV is local, and if they haven't all had a chance
> to finish before the calcout runs and uses the link then the link operation
> will fail and put the record into a LINK/INVALID alarm state.
> Try inserting an epicsThreadSleep(2) delay between iocInit and the dbpf
> command, which should be enough time for your local CA links to connect up.
Yes, inserting the delay makes the problem go away.
But this seems like a bug to me.  Isn't the IOC supposed to be
in the "running" state after iocInit completes?  I would expect
this to mean that any threads related to CA link processing have
completed starting and are in a state ready to service CA
requests.  I would not expect to have to insert epicsThreadSleep
calls after iocInit to make things work.
Also, I don't know exactly how the pause and run stuff works,
but if the IOC is paused and then run again at a later time,
will the same problem occur?  If so, I guess I'd have to add a
delay on coming out of the paused state to ensure my record will
process correctly.  That would be pretty lame.
Lewis
Re: Calcout using CA output link sometimes gets INVALID severity Ralph Lange
Re: Calcout using CA output link sometimes gets INVALID severity Andrew Johnson
Calcout using CA output link sometimes gets INVALID severity J. Lewis Muir
Prev: Re: Calcout using CA output link sometimes gets INVALID severity Andrew Johnson
Next: Re: Calcout using CA output link sometimes gets INVALID severity Ralph Lange
