Subject: Immediately reprocess a record [SEC=UNCLASSIFIED]
Date: Tue, 16 Oct 2012 22:19:13 +0000
I have a record (running in a 3.14.12.2 IOC) that I would like to process as quickly as it can. This record is retrieving a waveform over a LAN from a DSO and takes a variable amount of time to process (mostly 15 - 35 ms but periodically around 150 ms).
Currently I am using a sequence program that does a pvPut(wfRecProcField, SYNC) in a hard loop to achieve this. Is this the best method? Could I have done this using the database only?
Damien
Re: Immediately reprocess a record [SEC=UNCLASSIFIED] Andrew Johnson
Re: Immediately reprocess a record [SEC=UNCLASSIFIED] Tim Mooney
Prev: Re: gpu integration into epics Rodrigo Castro
Next: Re: Immediately reprocess a record [SEC=UNCLASSIFIED] Andrew Johnson
Prev: Re: Calcout using CA output link sometimes gets INVALID severity Andrew Johnson
