Subject: RE: JCA problems and questions
To: "'Matej Sekoranja'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 Oct 2012 20:37:13 +0000
Hi Matej,
Thanks for the reply.
Lewis also pointed out the new feature of caj.use_env to have CAJ use the traditional EPICS environment variables.  I am now using that in the areaDetector ImageJ plugin.  However, I have a couple of questions:
- What is the order of obtaining values from a JCALibrary.properties file versus the EPICS environment variables?
- Is the new caj.use_env documented anywhere except the single line in the change notes?
From: [email protected] [mailto:[email protected]] On Behalf Of Matej Sekoranja
Sent: Tuesday, October 23, 2012 3:33 PM
To: [email protected]
Subject: Re: JCA problems and questions
Rok Sabjan notified me about this thread. Thanks to Lewis for replies.
The old send buffer algorithm was to initialize the send buffer size to max_array_bytes and
automatically resize on demand (there is one send buffer per TCP connection). Not something
one would dare to use on a server, however very convenient on the client side.
However, if a client has a lot of connections there is a lot of memory required when max_array_bytes is large (e.g. 100 connection * 10MB = 1GB!).
Current algorithm starts with an initial size of 1k that can be automatically resized up to max_array_bytes.
This also mimics C++ CA algorithm (that has also evolved over the years).
Cheers,
Matej
RE: JCA problems and questions Chu, Paul
Re: JCA problems and questions Matej Sekoranja
Prev: Re: JCA problems and questions Matej Sekoranja
Next: RE: JCA problems and questions Chu, Paul
