Subject: Re: what are your definitions of softIOC and soft record?
To: "Ernest L. Williams Jr." <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Thu, 25 Oct 2012 14:04:50 -0400
Wow, what diverse views! Thank all for sharing your thoughts.
Ernest is right. The original term "IOC" covers every case. The term
"softIOC" seems to make simple thing complicated.
Toast,
JS
On Thu, Oct 25, 2012 at 11:13 AM, Ernest L. Williams Jr.
<[email protected]> wrote:
> On 10/25/2012 07:14 AM, Hu, Yong wrote:
>> I agree with Ben: no precise definition of softIOC. And there is no
>> 'official' definition: I tried to search "EPICS Application Developer’s
>> Guide" EPICS Base Release 3.14.12. But it seems there is no word 'softIOC'.
>> Also I made a quick search on Release Notes R3.14.12.2 [1] and found a few
>> words 'softIOC' and 'softIoc' mainly related to bugs or behavior change.
>> But I do have different view of '... softIOC as an IOC that does /not/
>> have direct access to "devices" ...'. Here is my case: I have made a
>> compactPCI-based data acquisition system which has several cPCI digitizers
>> and one cPCI CPU board. The CPU is running Debian/Linux. I create one IOC
>> for each digitizer so that each digitizer is independently controlled and
>> there are multiple IOCs parallelly running under Linux. In this case, I'd
>> like to say those IOCs are softIOCs. There is a Debian package named
>> 'sysv-rc-softioc' on NSLS-II Controls Package Repository [2] and we are
>> heavily using this package to manage all our production softIOCs.
> The original idea was that softIOC would mean no hardware (e.g. I/O)
> Here at SLAC with microTCA running on an embedded linux RTOS we were faced
> with the same question.
> Now, we have EPICS running as a process controlling real hardware.
> We decided not to call it a softIOC; indeed it is a hardIOC.
> Just my two cents :)
>> For me, softIOC has a very broad sense: the IOC(s) running on Windows
>> could be softIOC(s); the single IOC running on vxWorks or RTEMS could be
>> considered as a softIOC if it only contains soft records, if it accesses
>> devices through network, serial, etc, if it ...
> Even here, where we talk about serial/networked device control it is fuzzy.
> I also consider this real I/O just over some sort of fieldbus.
> Again, I believe the term softIOC is no longer appropriate.
> I propose we go back to just saying, "IOC"
> Let the term IOC cover cases of real I/O  or virtual I/O  :)
> Cheers,
> Ernest
>> Cheers,
>> Yong
>> [1] http://www.aps.anl.gov/epics/base/R3-14/12-docs/RELEASE_NOTES.html
>> [2] http://epics.nsls2.bnl.gov/debian/
>> -----Original Message-----
>> From: [email protected] [mailto:[email protected]]
>> On Behalf Of Benjamin Franksen
>> Sent: Wednesday, October 24, 2012 9:20 PM
>> To: [email protected]
>> Am Mittwoch, 24. Oktober 2012, 21:51:17 schrieb Jack Smith:
>>> Hello All,
>>> Here is my understanding of what is softIOC and what is soft record:
>>> 1. softIOC: any IOC (application/instance) running on Linux or Darwin
>>> is a softIOC since each softIOC is an independent process and multiple
>>> softIOCs can be running on the same physical machine. On the other
>>> hand, only one IOC can be running on vxWorks or RTEMS so that I would
>>> say IOC running on vxWorks or RTEMS is not a typical sofIOC. A softIOC
>>> can control real hardware.
>> I always thought of softIOC as an IOC that does /not/ have direct access
>> to "devices", accessing them only through network, serial IOC or some such.
>> That you can have more than one on the same physical machine never occurred
>> to me as a defining property for "softIOC".
>> I guess "softIOC" is a "soft term", there is no precise definition (and
>> therefore I'd argue the term is rather useless).
>>> 2. soft record: any record not associated with real hardware is a soft
>>> record. The DTYP field of a soft record is "Soft Channel" (default for
>>> DTYP), "Raw Soft Channel", or "Async Soft Channel".
>> Yes. You could improve this definition by stating that the INP or OUT link
>> must be of type pv_link (in teh sense of link.h in base), which includes any
>> potential future "soft" support type.
>> Cheers
>> Ben Franksen
Re: what are your definitions of softIOC and soft record? Ralph Lange
what are your definitions of softIOC and soft record? Jack Smith
Re: what are your definitions of softIOC and soft record? Benjamin Franksen
RE: what are your definitions of softIOC and soft record? Hu, Yong
Re: what are your definitions of softIOC and soft record? Ernest L. Williams Jr.
Prev: Privacy on Tech-talk Mailing List Jack Smith
Next: mbboDirect record initialization Rod Nussbaumer
Prev: Re: what are your definitions of softIOC and soft record? Ernest L. Williams Jr.
Next: Re: what are your definitions of softIOC and soft record? Ralph Lange
