Subject: extensionsTop 20120904 disable XRT/graph by default patch
To: EPICS Tech Talk <[email protected]>
Date: Fri, 26 Oct 2012 11:50:18 -0500
In extensionsTop 20120904 (from
http://www.aps.anl.gov/epics/extensions/configure/index.php),
XRT/graph is enabled by default for linux-x86.  This is a change
in behavior from previous releases where it was disabled by
default.  I think it is better for it to be disabled by default.
 Disabling it would also make it match linux-x86_64 where it is
disabled by default.  Attached is a patch.
Lewis
diff -ur extensions.old/configure/os/CONFIG_SITE.linux-x86.linux-x86 extensions.new/configure/os/CONFIG_SITE.linux-x86.linux-x86
--- extensions.old/configure/os/CONFIG_SITE.linux-x86.linux-x86	2009-05-19 15:48:13.000000000 -0500
+++ extensions.new/configure/os/CONFIG_SITE.linux-x86.linux-x86	2012-10-25 16:11:32.000000000 -0500
@@ -55,10 +55,10 @@
 ATLAS_LIB      = /usr/local/oag/3rdParty/ATLAS/Linux_Core2Duo32SSE3/lib
 ATLAS_INCLUDE  = /usr/local/oag/3rdParty/ATLAS/Linux_Core2Duo32SSE3/include
-# Define XRTGRAPH_EXTENSIONS = YES only if using XRT/graph 3.x
+# Define XRTGRAPH_EXTENSIONS = YES and XRTGRAPH only if using XRT/graph 3.x
 #   and you want the extensions for MEDM
-XRTGRAPH_EXTENSIONS = YES
-XRTGRAPH = /usr/local/xrtgraph
+#XRTGRAPH_EXTENSIONS = YES
+#XRTGRAPH = /usr/local/xrtgraph
 # Define SCIPLOT = YES if no XRT/graph 3.x
-#SCIPLOT=YES
+SCIPLOT = YES
Re: extensionsTop 20120904 disable XRT/graph by default patch Janet Anderson
Prev: probe 1.1.7.0 Xp_DIR patch J. Lewis Muir
Next: CSR/CR questions Bai Jiaoni
Prev: Re: probe 1.1.7.0 Xp_DIR patch Janet Anderson
Next: Re: extensionsTop 20120904 disable XRT/graph by default patch Janet Anderson
