Subject: Bug in iocLogServer
To: Tech Talk <[email protected]>
Date: Wed, 31 Oct 2012 13:25:08 -0500
I ran across a small bug in iocLogServer.c while trying to build it for an embedded ARM system.
There is a section in the routine seekLatestLine where EOF is compared to a 'char' variable - it
should be an int.
--- /home/jennings/development/epics/base-3.14.12.2/src/util/iocLogServer.c     2011-12-12 14:14:45.000000000 -0600
+++ /home/jennings/development/epics/iocLogServerStandalone/iocLogServer.c      2012-10-31 13:22:16.311818954 -0500
@@ -289,7 +289,7 @@
         else {
-            char c = fgetc (pserver->poutfile);
+            int c = fgetc (pserver->poutfile);
              * bypass the line if it does not match the expected format
Guy Jennings
Re: Bug in iocLogServer Andrew Johnson
Prev: Re: extensionsTop 20120904 disable XRT/graph by default patch Janet Anderson
Next: Re: Bug in iocLogServer Andrew Johnson
Prev: RE: How to debug an IOC running on MSWindows using windbg Ahed Aladwan
