Hi:
Looks like the NSLSII version is configured such that it wants to log errors/warnings/messages to a file, and opening that file (logs/CSSLogFile) fails.
You can fix that by disabling the file logging via the preference GUI, or via the preference settings taken from a file.
See http://cs-studio.sourceforge.net/docbook/ch06.html for how the hierarchical preferences work.
The specific setting for NOT logging to a file is: Set an empty file_pattern:
## Logging
org.csstudio.logging/console_level=WARNING
org.csstudio.logging/file_level=CONFIG
org.csstudio.logging/jms_level=SEVERE
org.csstudio.logging/file_pattern=
org.csstudio.logging/jms_url=
-Kay
From: James F Ross <[email protected]<mailto:[email protected]>>
Date: Wednesday, November 7, 2012 10:25
To: Kasemir Kay <[email protected]<mailto:[email protected]>>
Cc: Pavel Maslov <[email protected]<mailto:[email protected]>>, "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
Subject: Re: using CSS data browser
Hello,
I continue to struggle with the CSS data browser. Just as a reference, I downloaded the NSLSII build of CSS. There is still a problem (or problems) that I need to overcome. When I run the start up script, I get a series of errors, the output is below. Does anyone have any familiarity with these errors?
Thanks!
James
java.io.IOException: Couldn't get lock for logs/CSSLogFile
at java.util.logging.FileHandler.openFiles(FileHandler.java:370)
at java.util.logging.FileHandler.<init>(FileHandler.java:344)
at org.csstudio.logging.LogConfigurator.configureFileLogging(Unknown Source)
at org.csstudio.logging.LogConfigurator.configureFromPreferences(Unknown Source)
at org.csstudio.nsls2.product.startupmodule.Workbench.runWorkbench(Unknown Source)
at org.csstudio.startup.application.Application.startApplication(Unknown Source)
at org.csstudio.startup.application.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
2012-11-07 09:22:12.294 INFO [Thread 10] org.csstudio.auth.internal.usermanagement.LoginContext (login) - No login module provided. The system acts as anonymous login
2012-11-07 09:22:13.778 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:13.779 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:13.780 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:13.780 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:13.781 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:13.781 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:13.992 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:13.992 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:13.994 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:13.994 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:13.996 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:13.996 INFO [Thread 11] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:14.027 INFO [Thread 12] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:14.027 INFO [Thread 12] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:14.029 INFO [Thread 12] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:14.029 INFO [Thread 12] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:14.030 INFO [Thread 12] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:14.030 INFO [Thread 12] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:14.034 INFO [Thread 13] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:14.034 INFO [Thread 13] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:14.036 INFO [Thread 13] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:14.036 INFO [Thread 13] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
2012-11-07 09:22:14.037 INFO [Thread 13] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - I/O exception (java.net.ConnectException) caught when processing request: Connection refused
2012-11-07 09:22:14.037 INFO [Thread 13] org.apache.commons.httpclient.HttpMethodDirector (executeWithRetry) - Retrying request
On Tue, Nov 6, 2012 at 9:10 AM, James F Ross <[email protected]<mailto:[email protected]>> wrote:
Thank you everyone for the information! I'll get started on that and ask if I have any further questions.
James
On Tue, Nov 6, 2012 at 8:49 AM, Kasemir, Kay <[email protected]<mailto:[email protected]>> wrote:
Hi:
Once you figured out what preference settings you need for users at your site, you can put those into a plugin_customization.ini file and run CSS with a command-line option
css -pluginCustomization /path/to/your/plugin_customization.ini
Ideally, you create a CSS product for users at your site that includes all the plugins that you want for your site and you put that plugin_customization.ini into that product plugin, so no command-line option is needed. As an intermediate step, you can use one of the existing products from NSLS2 or SNS or .. and replace the plugin_customization.ini in there.
Read the chapter on "Hierarchical Preferences" in http://cs-studio.sourceforge.net/docbook/ for more.
In there you'll also find info on archiver setup, how to import existing archive configurations
>Does the RDB archiver use a similar setup to the channel access archiver?
Yes, read "ArchiveConfigTool" on http://cs-studio.sourceforge.net/docbook/ch10.html
Kay
From: James F Ross <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>
Date: Monday, November 5, 2012 16:06
To: Pavel Maslov <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>
Cc: "[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>" <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>
Actually I managed to find it just a moment ago. It's under Edit -> Preferences -> CSS Applications -> Trends -> Data Browser -> Default Archive Data Sources. I think it's just a preferences thing with no need to recompile, but we'll see.
I likely will want to use the relational database archiver, but I'll likely need to get that going first, assuming it is separate from CSS (I'm rather new at CSS and any EPICS archiver). We are currently using the old channel access archiver and the archive viewer to view the databases.
For the moment, I'm simply trying to get the data browser to view the old archive in place of the archive viewer.
I do have a question though on the relational database archiver. Does the RDB archiver use a similar setup to the channel access archiver? That is, does it still use .xml files as index files to tell the archiver when and how to monitor EPICS channels?
Thanks for your help!
James
On Mon, Nov 5, 2012 at 2:49 PM, Pavel Maslov <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
Hey James,
In case you'd like to use BEAUTY and BEAST as the archiving system and alarm system respectively, you'd have to edit the source code in Eclipse RCP, then compile everything (CSS, Archive server, Alarm server). But I guess, if you know the address of the relational database, login and password, you can adjust it in the Preferences.
Or do you wish to use another archiver I'm completely ignorant of?
On Mon, Nov 5, 2012 at 8:34 PM, James F Ross <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
Hello everyone,
I've downloaded CSS for use at STAR. I hope to replace the old channel archiver and use the data browser instead, but I'm having trouble getting it to work. I downloaded the NSLSII version since they are located at Brookhaven National Lab as well but it came preconfigured for their setup. Specifically, when I start it up it automatically tries to load ArchiveDataServer.cgi from their location. I know where this file is located on our machine, but I need to know how to change this path, as well as any other NSLSII specific settings. Can this be configured from the workspace or do I have to do it somewhere in the source code?
Thanks a lot!
James Ross
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19<tel:%2B7%20%28951%29%20672%2022%2019><tel:%2B7%20%28951%29%20672%2022%2019>
Landline: +7 (812) 461 01 01<tel:%2B7%20%28812%29%20461%2001%2001><tel:%2B7%20%28812%29%20461%2001%2001>
- Re: using CSS data browser James F Ross
Re: 3.14 v.s. 3.15 vs. v4 Andrew Johnson
<2012>
2025
2026
Proposed addition of property in Open OPI in view Action Patard Charles-Henri
<2012>
2025
2026
