Subject: |
Long string support in CA clients and device support |
Andrew Johnson <[email protected]> |
To: |
"EPICS tech-talk" <[email protected]> |
Date: |
Mon, 12 Nov 2012 17:24:52 -0500 |
Mark Rivers has asked for clarification on how software should handle string
termination when dealing with long strings (i.e. using DBF_CHAR arrays such as
a waveform record to hold string data).
I recommend (but we don't require) that anything generating a long string
should add a Nil ('\0') terminator byte after the last character and count
that in the number of elements reported for the array (e.g. when setting the
waveform record's NORD field).
However clients that read an array as a long string MUST be able to properly
handle one that doesn't have a Nil terminator, and should not report an error
in this case. The simplest way to ensure proper termination is to check if
the byte at [len-1] is zero and if not append one (making sure you reserved
space in your buffer for it).
Code should always call strlen() to find the actual length of the long string
and not rely on the array length, since there may be any number of trailing
zero bytes included in the array data.
Clients that don't append a terminator may be protected by the recommendation
in the second paragraph above, but not in all circumstances (for example if
you request fewer elements than there are characters present in the string you
will not get a terminating Nil byte, which could cause your program to crash).
Mark is modifying asynPortDriver to append the Nil bytes where possible, but
some Asyn APIs such as asynOctet support must work with binary data as well as
text and cannot be changed.
- Andrew
READ CAREFULLY. By reading this email, you agree, on behalf of your
employer, to release me from all obligations and waivers arising from
any and all NON-NEGOTIATED agreements, licenses, terms-of-service,
shrink-wrap, click-wrap, browse-wrap, confidentiality, non-disclosure,
non-compete and acceptable use policies ("BOGUS AGREEMENTS") that I
have entered into with your employer, its partners, licensors, agents
and assigns, in perpetuity, without prejudice to my ongoing rights
and privileges. You further represent that you have the authority to
release me from any BOGUS AGREEMENTS on behalf of your employer.
Re: strange EPICS glitch Eric Norum
Re: strange EPICS glitch Andrew Johnson
<2012>
2025
2026
RE: Long string support in CA clients and device support Mark Rivers
<2012>
2025
2026
