Subject: DB Question
Date: Fri, 16 Nov 2012 08:32:26 -0800
I am a bit confused by the following behavior.
I am using EPICS R3.14.12.2 and asyn R4.20.
I have a simple longout record:
record( longout, "$(P):$(N):LO:BTOI:NCOEF"){
  field( DESC, "N Coefs:")
  field( DTYP, "asynInt32")
  field( OUT,  "@asyn($(PORT),$(N),1)LO_NCOEF")
 field( VAL,  "2")
  field( PINI, "1")
After this record is done initializing, caget on it gives me 0.
I have introduced another record as follows:
record( longout, "$(P):$(N):LO:NCOEF"){
  field( VAL,  "2")
  field( OUT,  "$(P):$(N):LO:BTOI:NCOEF PP")
  field( PINI, "1")
# field( VAL,  "2")
#  field( PINI, "1")
With these two records the second one now has the correct value.
Why does the single record solution lose its VAL value?
Thanks in advance,
Zen
RE: DB Question Mark Rivers
Prev: Re: Long string support in CA clients and device support Andrew Johnson
Next: RE: DB Question Mark Rivers
Prev: Re: streamDevice Exception Handler Question Dirk Zimoch
