Subject: Re: Get a time difference in EPICS database
To: 洪春霞 <[email protected]>
Cc: [email protected]
Date: Fri, 23 Nov 2012 22:46:55 -0600 (CST)
hongchunxia,
Two things:
1) If you are using the soft time device support in EPICS base, and you want to use a calc record to calculate the time difference, you should not get the time as a formatted string, but instead get it as the raw number of seconds since the fixed "epoch" (which I think is some time back in 1990 or something):
record(ai,"time1") {
    field(DTYP, "Soft Timestamp")
record(ai,"time2") {
record(calcout,"timeDiff") {
    field(DESC,"time2-time1 (seconds)")
    field(INPA,"time1 NPP")
    field(INPB,"time2" NPP)
    field(CALC,"b-a")
2) I don't see anything in your database that would cause h:Systemtime2 to process.  I think your job might be easier if you separate the job of deciding whether h:Systemtime2 should process, from the job of calculating the difference between h:Systemtime1 and h:Systemtime2.
Tim Mooney
----- Original Message -----
To: [email protected]
Sent: Friday, November 23, 2012 2:07:26 AM
Subject: Get a time difference in EPICS database
I want to get a time difference in EPICS database, the record of h:Systemtime1 is run when ioc is start, that is, it is the realtime time.
The record of h:Systemtime2 is get when A=3 in the record(calcout,"h:monitor_time"), and it should be executed once, but now I can not get the time of h:Systemtime2.
When I input “camonitor h:Systemtime2” in another Terminal, I always get “h:Systemtime2 <underfined> UDF INVALID”,and I input “camonitor h:time_plus” in another Terminal, I get the time is the value of C.
That is to say, the record of h:Systemtime2 is not executed.
Can you give me some advice? Thank you very much.
Best Wishes.
The database which I use is as follows:
record(ai, "h:status")
record(stringin,"h:Systemtime1")
field(DESC,"Systemtime1")
field(DTYP,"Soft Timestamp")
field(SCAN,"1 second")
field(PINI,"YES")
field(INP,"@%s")
record(stringin,"h:Systemtime2")
field(DESC,"Systemtime2")
field(INP,"@%s")
field(DISV,"0")#If DISV=DISA, then the record will be disabled
field(SDIS,"h:monitor_time PP MS")#
#This is the value that is compared with DISV to determine if the record is
#disabled. Its value is obtained via SDIS if SDIS is a database or channel access
#link.
record(calcout,"h:time_difference")
field(CALC,"A=B?(C-D):0")
field(INPA,"h:status PP NMS")
field(INPB,"3")
field(INPC,"h:Systemtime1 PP NMS")
field(INPD,"h:Systemtime2 NPP NMS")
field(OUT,"h:time_plus PP NMS")
field(OOPT,"Transition To Non-zero")
hongchunxia
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
答复: Get a time difference in EPICS database 洪春霞
Prev: Utilities for EPICS on Multi-Core Linux Ralph Lange
Next: 答复: Get a time difference in EPICS database 洪春霞
Prev: Get a time difference in EPICS database 洪春霞
