1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: compiling EPICS Channel Archiver using epics.4.14.7 on 32 bit scientific linux
To: EPICS Tech Talk <[email protected]>
Date: Mon, 26 Nov 2012 14:41:54 -0500
Hello everyone.  As I've mentioned in previous posts I'm trying to get
the channel archiver working on a new machine that we recently set up.
 To this end, I've decided to try compiling the archiver on the old
machine again and try to get it working there, so I can learn about
the whole process and see if I can find out what the problem is.  I've
followed the instructions in section 7 of the manual, but when I try
'make' in the ChannelArchiver directory, I get the following final
lines before the error.  Anyone run into this problem before?  Any
ideas?  My version of gcc is 3.2.3.  Thanks!
James Ross
VERSION_TXT=\"2.9.2\" -IOME/include
-I/home/sysuser/epics.3.14.7/base-3.14.7/include
-I/home/sysuser/epics.3.14.7/base-3.14.7/include/os/Linux
-I/usr/local/xerces-c-src2_4_0/include      -g -fPIC -I. -I..
-I../../../../include/os/Linux -I../../../../include
../BinArchive.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi  -g  -Wall     -D ARCH_VERSION=2 -D ARCH_RELEASE=9
-D ARCH_PATCH=2 -D ARCH_VERSION_TXT=\"2.9.2\" -IOME/include
../BinChannel.cpp
../BinChannelIterator.cpp
../../../../include/RegularExpression.h: In member function
   `BinChannelIterator& BinChannelIterator::operator=(const
   BinChannelIterator&)':
../../../../include/RegularExpression.h:58: `
   RegularExpression::~RegularExpression()' is private
../BinChannelIterator.cpp:22: within this context
../../../../include/RegularExpression.h:54: `
   RegularExpression::RegularExpression(const RegularExpression&)' is private
../BinChannelIterator.cpp:24: within this context
../BinChannelIterator.cpp: In member function `void
   BinChannelIterator::attach(BinArchive*, const DirectoryFileIterator&, const
   char*)':
../BinChannelIterator.cpp:39: no matching function for call to `
   RegularExpression::RegularExpression(const char*&)'
../../../../include/RegularExpression.h:57: candidates are:
   RegularExpression::RegularExpression()
../../../../include/RegularExpression.h: In member function `void
   BinChannelIterator::clear()':
../BinChannelIterator.cpp:47: within this context
make[2]: *** [BinChannelIterator.o] Error 1
make[2]: Leaving directory
`/home/sysuser/epics.3.14.7/extensions/src/ChannelArchiver/LibIO/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory
`/home/sysuser/epics.3.14.7/extensions/src/ChannelArchiver/LibIO'
make: *** [LibIO.install] Error 2
Prev: usb over ethernet John William Sinclair
Next: Re: Error building asyn4-20 on CentOS 6.3 Andre Charbonneau
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: posix osiSpawnDetachedProcess inherits scheduling policy + priority Till Straumann
