1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using CAJ in production
To: "Shankar, Murali" <[email protected]>
Date: Thu, 29 Nov 2012 14:40:58 -0500
To clarify, a monitor won't clear in CAJ without an explicit IO flush. In JCA/JNI, the monitor will clear without the IO flush, so the behavior is different.
On Nov 29, 2012, at 1:39 PM, "Pelaia II, Tom" <[email protected]<mailto:[email protected]>> wrote:
Hi Murali,
Another long standing issue is that monitors won't clear which is a serious problem. We are using version 1.1.5b. I haven't seen any note indicating this has been fixed in any later version.
We only use the JCA/JNI version in our control system.
best regards,
Tom
On Nov 29, 2012, at 1:30 PM, "Shankar, Murali" <[email protected]<mailto:[email protected]>> wrote:
Just wanting to check if anyone uses CAJ (pure Java CA client) clients in production especially in combination with IOC's that are using the native CA library.
I've pinged a few folks offline; however, it was thought that a community wide repoll would probably be beneficial.
Known issues that I am already aware of (thanks Michael and Eric)
1) Interoperability issue with the CA Gateway and clients using monitors with DBE_PROPERTY.
2) For CA Access Security, CAJ uses full hostnames (with domain) and libca uses short host names (without domain)
3) The issue with EPICS_CA_MAX_ARRAY_BYTES  has already been fixed.
Has anyone encountered any issues/differences on the IOC side?
Murali
Re: Using CAJ in production J. Lewis Muir
Using CAJ in production Shankar, Murali
Re: Using CAJ in production Pelaia II, Tom
Prev: Re: Using CAJ in production Pelaia II, Tom
Next: Re: Using CAJ in production J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
