Subject: Re: Using CSS and setting up RDB Archiver
To: James F Ross <[email protected]>
Date: Mon, 3 Dec 2012 16:15:16 -0500
Hi:
>From:  James F Ross <[email protected]
>With the exception of org.csstudio.archive.rdb, these are all imported
>from SNS snapshot 3.0.2 rather than 3.1.2, so that may be part of it.
I assume that's the issue.
What version of the IDE are you using, or more to the point: What's the
target platform in case you're not using the IDE as the target platform?
When you're using Eclipse 3.7.2 and the SNS 3.1.2 source snapshot, you
should be fine.
With other combinations,
>Is there a good way to find out what errors CSS is sensing in these
>plugins?  Or will I have to go through each error and find any other
>missing plugins?
Yes, fundamentally you have to look for each error and figure it out.
-Kay
On Mon, Dec 3, 2012 at 9:39 AM, Kasemir, Kay
<[email protected]> wrote:
You need to use a version of Eclipse that matches the version of the
source code.
The SNS source snapshot for CSS 3.1.2 for example,
https://ics-web.sns.ornl.gov/css/products.html, supports Eclipse 3.7.2 as
a target platform.
If you have different sources or a different target platform, you can try
to resolve the plugin dependencies as described in  Fix Dependencies on
http://cs-studio.sourceforge.net/docbook/ch15.html, but that is tedious.
Overall it's best to start with a matching set of sources and Eclipse IDE.
Re: Using CSS and setting up RDB Archiver James F Ross
Prev: Re: Using CSS and setting up RDB Archiver James F Ross
Next: RE: caRepeater object code not cross-compiled in R3.14.12.2 Hill, Jeff
Next: Tektronix 3014 IOC Errors Trevor Downer
