Subject: Registering DBD files and iocshRegisterCommon
To: <[email protected]>
Date: Wed, 5 Dec 2012 07:38:30 +0000
I have two questions:
1. Is iocshRegisterCommon() defined to be idempotent (ie, safe to call repeatedly)?
2. Is what I'm trying to do below sane?
I am looking into creating a mechanism for dynamically loading EPICS support modules and it looks as if I need to add an xxx_registerRecordDeviceDriver.cpp file to each support module that I wish to be able to use so that I have a dbd registration function available to call.
Loading a dynamically generated support module requires the following steps:
1. Load the .so file.
2. Load the .dbd file (dbLoadDatabase seems to serve).
3. Register the dbd functionality.
Of course, step 3 is the tricky one.  I've experimented by adding the appropriate <module>_registerRecordDeviceDriver.cpp to the support module's build and then dynamically invoking the generated <module>_registerRecordDeviceDriver function ... and everything seems to work, but I am worried by one small detail.
The generated code, generated by registerRecordDeviceDriver.pl from the module's .dbd file, is straightforward enough, but it always includes a call to iocshRegisterCommon() which gets called at C++ static constructor initialisation time ... which means if I'm generating register functions for every support module *and* for my base IOC this function will be called repeatedly.  I imagine there's no particular guarantee that this function is idempotent, is there?
First of all, is this a sane approach for what I'm trying to achieve?
Secondly, is this safe at the moment?  I've dug into iocshRegisterCommon and its calls, and its work seems to devolve to numerous calls to iocshRegister, which looks properly monotonic to me, so I'm encouraged to proceed.
Could we perhaps make the fact that iocshRegisterCommon can safely be called repeatedly more explicit by applying the following patch?
diff --git a/src/misc/iocshRegisterCommon.c b/src/misc/iocshRegisterCommon.c
index 3e027eb..838de43 100644
--- a/src/misc/iocshRegisterCommon.c
+++ b/src/misc/iocshRegisterCommon.c
@@ -21,8 +21,14 @@
 #include "miscIocRegister.h"
 #include "iocshRegisterCommon.h"
+static int initialised = 0;
 void epicsShareAPI iocshRegisterCommon(void)
+    if (initialised)
+        return;
+    initialised = 1;
     iocshPpdbbase = &pdbbase;
     dbStaticIocRegister();
Re: Registering DBD files and iocshRegisterCommon Andrew Johnson
Prev: RE: Initializing starting position on a Motor Mark Rivers
Next: EPICS driver for E-517 Rau, Steffen
Prev: RE: Initializing starting position on a Motor Tonia Batten
Next: Re: Registering DBD files and iocshRegisterCommon Andrew Johnson
