Subject: Re: Converting raw to eng in a waveform
To: Di Maio Franck <[email protected]>
Cc: Kim Changseung <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 5 Dec 2012 11:42:26 -0500
Franck,
I developed an ADC model-specific custom record (supported hardware config/monitor and metadata to construct scaled waveform).  I wrote a CA client program to assemble amplitude/units/time scaled waveform using the custom record and raw waveform.  This program also converted the resultant waveform and metadata for non-EPICS data repository.
This was in 1999.  I have long had plans to eliminate the client program.
-ps
On Wed, Dec 5, 2012 at 11:12 AM, Di Maio Franck <[email protected]> wrote:
Dear all
We have a question about implementing device support for an ADC that returns values in a waveform record, not using asyn.
If we want the data to be converted from the ADC voltage range into user's engineering data, we need engineering limits or scaling factors or...
Seems that waveform is not as detailed as ai for that.
I guess that we are not the only one in the globe having this issue.
I'll appreciate to have some indication on the implementation.
Thanks!
Franck
Franck Di Maio
ITER Organization, Building 72/279, CHD, Control System Division
Route de Vinon sur Verdon - 13115 St Paul Lez Durance - France
Phone: +33 4 42 17 64 05
Converting raw to eng in a waveform Di Maio Franck
Prev: Re: Converting raw to eng in a waveform Tim Mooney
Next: Re: Registering DBD files and iocshRegisterCommon Andrew Johnson
Next: RE: Converting raw to eng in a waveform Hill, Jeff
