Subject: Re: .PACT .TIME
To: Pavel Maslov <[email protected]>
Date: Wed, 12 Dec 2012 15:43:48 +0100
Pavel,
maybe you could make use of the timestamp record. It will update it's value if it is linked to your record. That you can display on the screen.
Rok
On 12. dec. 2012, at 15:35, Pavel Maslov wrote:
Leo,
I need an operator (the client) to see if the record has been processed. Your advice works on the IOC side only.
On Wed, Dec 12, 2012 at 5:54 PM, Dalesio, Leo <[email protected]> wrote:
Login and set the TPRO field to a non zero value.
It will print the name of the record and every passive record processed in this lock set after the record with the TPRO field set to 1.
Or, set the deadband of an AI or CALC to -1. It will post the VAL field each time as the absolute value of the change will exceed it.
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Maslov
Sent: Wednesday, December 12, 2012 8:39 AM
To: EPICS Tech Talk
Subject: .PACT .TIME
Is there a way I can subscribe to these record fields?
I would like to know if my record has been processed.
The record itself is being processed ~30 seconds.
It's strange when I caget record.PACT I can see 1 or 0. However, camonitor doesn't react on the value change whatsoever.
Is there any other way around?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
.PACT .TIME Pavel Maslov
Re: .PACT .TIME Pavel Maslov
Prev: RE: .PACT .TIME Dalesio, Leo
Next: RE: .PACT .TIME matthew.pearson
Prev: Re: .PACT .TIME Pavel Maslov
