Subject: Re: How to get a list of all available PVs
To: [email protected]
Date: Wed, 19 Dec 2012 11:21:07 +0100
First of all, thanks to all for the many tips and pointers. I have a much
clearer vision now. And sorry for the silence (I was out of office yesterday) .
So summarizing the info in this thread:
If I want to provide a Taurus "model chooser"[1] for Epics similar to what we
have for Tango, I probably need to create a plugable mechanism to abstract the
source of information about available records and/or PVs, since I cannot hope
for a standard source. Some plugins that could be written are:
a) a plugin that relies on ChannelFinder [2]. ChannelFinder appears to be in
use by many. In this case it is up to each facility to keep the DB updated
with the PV names that they consider relevant
b) a plugin combining a beacon-based detection of active IOCs with a query to
those IOCs using the pvListServer [3]. In this case it is up to each facility
to run the pvListServer in all the IOCs that they consider relevant.
c) a dummy plugin allowing to provide a file-based list of names. How this list
is created is left up to the facility.
That said, having this info available is convenient but not mandatory for
using taurus. For example, in its current status it is possible to display PVs
in a TaurusForm widget by executing, e.g.:
$> taurusform epics://some_pv_name
You are more than welcome to try it out, but please remember that epics
support is just a proof-of-concept for the moment. For starters, Taurus won't
start if Tango is not installed. We are working in making this dependency
optional, but it will take some time. On the bright side, however, Taurus and
Tango are now part of the official repositories of Debian Wheezy and Ubuntu
12.10, so installing taurus with all its dependencies can be done with just:
$> sudo apt-get install python-taurus
Of course, for testing the epics support, you need to install also the latest
svn version of taurus[4] and use it instead of the one installed from the
repositories.
[1] http://www.tango-
controls.org/static/taurus/latest/doc/html/users/ui/modelchooser.htm
[2] http://channelfinder.sourceforge.net/
[3] http://ics-
web4.sns.ornl.gov/pvlistserver/log/show.php?mon=Apr&theDay=30&year=2004
[4]http://www.tango-
controls.org/static/taurus/latest/doc/html/users/getting_started.html#working-
from-svn
 Carlos Pascual Izarra
 Scientific Software Coordinator
 Computing Division
 Cells / Alba Synchrotron  [http:/www.cells.es]
 Carretera BP 1413 de Cerdanyola-Sant Cugat, Km. 3.3
 E-08290 Cerdanyola del Valles (Barcelona), Spain
 E-mail: [email protected]
 Phone: +34 93 592 4428
How to get a list of all available PVs Carlos Pascual
Prev: EPICS Base R3.14.12.3 now available Andrew Johnson
Next: Re: How to get a list of all available PVs Dirk Zimoch
Prev: RE: How to get a list of all available PVs Mark Rivers
Next: Re: How to get a list of all available PVs luedeke
