Subject: Re: SNL with C
To: "Zelazny, Michael Stanley" <[email protected]>
Date: Wed, 19 Dec 2012 18:37:04 -0600
Great!  Thank you and Mark.
Another question: if I want to write a C function, I understand that it needs to be
after the last SNL statement.  Does it belong outside of the ss SS1 {} block, or
is it after the last statement within the block.  Is it true that this code would
also need to be escaped %{ short myFunc() {} }%?
Best regards,
Pierrick
On 12/19/2012 06:11 PM, Zelazny, Michael Stanley wrote:
try putting your statement in an "entry" block.  And, as Mark says, the "%%" probably isn't necessary.
ss SS1 {
  state Offline {
    /* Get PV relevent PV information */
    when (SS1mon == 1) {
      SS1state = 1;
      pvPut(SS1state);
    } state Pumping
  state Pumping {
    entry {
    %%if (StateReadCDB()) printf("SS1-Pumping: success\");
    when (SS1vac <= 1.0e-4) {
      SS1state = 2;
      pvPut(SS1state);
    } state Pumped_Warm
... continued
From: [email protected] [[email protected]] On Behalf Of Pierrick M Hanlet [[email protected]]
Sent: Wednesday, December 19, 2012 3:59 PM
To: [email protected]
Subject: SNL with C
I a newcomer to SNL.
I have a library to which I link my snl.  In a global entrance block, I can successfully call
one of the functions.  Later I added the use of another function in a state set and now
I can no longer compile.
ss SS1 {
  state Offline {
      SS1state = 1;
      pvPut(SS1state);
    } state Pumping
  state Pumping {
      SS1state = 2;
      pvPut(SS1state);
    } state Pumped_Warm
... continued
The error at compilation/linking is:
converting ../sncMICEStates.stt
/home/epics/epics/Support/seq/bin/linux-x86/snc +r   ../sncMICEStates.stt -o sncMICEStates.c.tmp
syntax error: line no. 96 (../sncMICEStates.stt)
     state option list
make[3]: *** [sncMICEStates.c] Error 1
make[3]: Leaving directory `/home/epics/epics/iocTops/MICEStates/MICEStatesApp/src/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/epics/epics/iocTops/MICEStates/MICEStatesApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/epics/epics/iocTops/MICEStates/MICEStatesApp'
make: *** [MICEStatesApp.install] Error 2
where line no. 96 is the escaped call to the library function in my Pumping state.  The error "state option list"
doesn't tell me anything.
Help please,
Pierrick
"Whether you think you can or think you can't, either way, you are correct"
-- Henry Ford
_________________________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-697-8758 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-7-948-860-1978 (US/UK mobile)
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
RE: SNL with C Zelazny, Michael Stanley
RE: SNL with C Mark Rivers
SNL with C Pierrick M Hanlet
Prev: RE: SNL with C Zelazny, Michael Stanley
Next: RE: SNL with C Zelazny, Michael Stanley
