1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamDevice: how to read a value as fast as possible?
To: [email protected]
Date: Fri, 21 Dec 2012 15:49:55 -0600
Hi Martin,
On 2012-12-21 Martin Konrad wrote:
> 2. A free-running mode (device automatically starts the next acquisition
> as soon as the first one is finished). In this mode the interface is
> never blocked and data can always be read out with the "FETCH?" command
> which immediately returns the last reading. Using this command with
> SCAN=".1 second" leads to a lot of unneeded record processing (as well
> as CA traffic to clients that monitor this PV and also archiving load).
> Is it possible to avoid processing of my ai record if the VAL field did
> not change? It seems to me that this is a limitation caused by the
> asynchronous behavior of Asyn/StreamDevice...
> Any ideas?
You can avoid passing the changing data up through CA by setting the MDEL
field of your ai record, but you can't stop the record processing.  The
default value of MDEL=0 makes it only send values that are not bit-for-bit
identical, but if you have random noise on your input you may need to increase
it to whatever value is sufficient to suppress that, as long as that doesn't
affect the signal you're reading out.
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
streamDevice: how to read a value as fast as possible? Martin Konrad
Prev: RE: streamDevice: how to read a value as fast as possible? Mark Rivers
Next: Re: streamDevice: how to read a value as fast as possible? Martin Konrad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: streamDevice: how to read a value as fast as possible? Martin Konrad
Next: Error in installing asyn driver nalaka samarasinghe
