caget uses ports 5064 and 5065 by default. It uses UDP to locate which IOC has the PV, and then TCP to read the value.
The fact that you can ping makes it sound like there is a firewall somewhere blocking ports 5064 or 5065. Those both need to be open for both UDP and TCP.
On Behalf Of James F Ross
Sent: Thursday, December 27, 2012 12:51 PM
To: EPICS Tech Talk
Subject: unable to see epics variables
Hello everyone,
I am not sure if this is an epics problem or not, but if anyone has any insight I would appreciate the help. The error is the following:
$> caget fgt:status
CAC: Unable to connect because "No route to host"
CA.Client.Exception...............................................
Warning: "Virtual circuit disconnect"
Context: "softioc3.starp.bnl.gov:52008"
Source File: ../cac.cpp line 1214
Current Time: Thu Dec 27 2012 13:44:42.760798000
cagChannel connect timed out: 'fgt:status' not found.
I have been unable to find anything blocking a route to the host, and I can ping the host from the machine I am trying the caget on. Historically this has been caused by firewall issues, but even with all security (iptables and selinux) disabled I still get
this problem. Is there anything epics related that can cause this issue? Something that isn't running but should be in order to allow the command caget to connect?
It would be helpful to know exactly how caget looks over a network. Is there a particular port it uses? Does it look via rsh or NFS or some other connection type that may not be working for some reason?
Three machines spontaneously started having this issue which points to it being a network problem and thus nothing tech talk can help me with, but the fact that I can ping each host from the three machines having problems indicates that there is in fact a network
connection and may be epics related.
Thanks for the help,
James Ross
- Re: unable to see epics variables Pavel Maslov
- unable to see epics variables James F Ross
Question from the dark past: CGIExport Maren Purves
<2013>
2025
2026
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
