Hi Benjamin,
On 2012-12-18 Benjamin Franksen wrote:
> On Wednesday, December 12, 2012 14:16:12 Mark Rivers wrote:
> > I don't think that PACT would really be considered "metadata".
> > But this Web page explains which fields in dbCommon do post monitors
> > https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon
> Posting monitors for PACT would be a most welcome addition. Maybe this
> could be added in 3.15?
That would require changes to every record type's process() routine [which I
couldn't do for record types not in Base], and would hit performance. Every
call to db_post_event() requires it to search the record's list of CA clients,
comparing the posted address with that of the subscribed field for every
subscriber, and for PACT there would be two calls since it changes twice per
process.
It /might/ be possible to make the .TIME field accessible over CA and post
monitors on it from within recGblGetTimeStamp(), but I haven't looked at the
code changes necessary to implement that. The native type of the TIME field
would probably become ULONG[2] but I'd like to make it accessible as a string
as well, and doing all that might need some deep changes so no promises.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- Re: .PACT .TIME Benjamin Franksen
Re: epics input and output via records Wesley Moore
Re: epics input and output via records James F Ross
<2013>
2025
2026
unable to see epics variables James F Ross
<2013>
2025
2026
